Old 03-19-2009, 19:24   #1 (permalink)
jepetu's Avatar
Member: 181633
Alcatel S319x unlocked in one pass
Other box can't read unlock codes because is a new revision.
Thanks Infinity!
COM5 [VCP0] selected
module  v2.68
Device: Alcatel-S319X, S319A
Checking data, wait...
Action: write NOR flash
"smart write" active
"format ffs" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:3871:A00C
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 98004900000002:2AEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 detection finished
identification#1 protocol ver: 05
ver. sw 1: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP1_V20.BIN
ver. sw 2: MAUI.07A.W07.36.SP1.V20, 00000000
ffs offset/size: 00C00000/00400000
detect device identification#2...
detect device identification#2 finished
sim-lock status: enabled
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\system_log__JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP1_V20.BIN_FFFFFFFF_20090319-140731.B0X.bin
Area: Firmware
Write: Firmware
security area (code #3, part #2) calculation...
customization: CH16JB10
done
Write: security area (code #3, part #2)
security area (code #3, part #2) calculation done
security area (code #3, part #1) calculation...
use default security area (code #3, part #1) pattern
..................security area (code #3, part #1) detecting size...
security area (code #3, part #1) detecting parameters...
security area (code #3, part #1) encoding...
done
Write: security area (code #3, part #1)
security area (code #3, part #1) calculation done
Write Done
Finalization ...
formatting...
Finalization Done
file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\system_log__JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP1_V20.BIN_FFFFFFFF_20090319-141745.B0X.bin
Finished, time used: 640 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
The Following User Says Thank You to jepetu For This Useful Post:
Old 03-20-2009, 21:49   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Infinity!
module  v2.68
"format ffs" active
write: Firmware
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
status: 01
Boot Done
Initialize ...
Initialize Done
Set baud ...
460800
Set baud Done
Write ...
Area: Firmware
Write: Firmware
done
done
Write Done
Finalization ...
formatting...
Finalization Done
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type)
and what is possible problems (so we will be able to fix it) and successfully done work.
Old 03-23-2009, 12:59   #3 (permalink)
Member: 255638
Hello sir it is old verson no new verson orange uk is new verson.this verson unlock after white screen.any idia.
alcatel s319x unlock problem gurinder Infinity-Box 43 11-16-2009 21:51
Pls help with alcatel s319x unlock TALIAT Infinity-Box 3 08-02-2009 14:12
Alcatel S319X unlock done but no service kemot Infinity-Box 4 06-20-2009 07:37
Alcatel s319x unlock ok but help Lutfur Infinity-Box 0 04-22-2009 09:29
alcatel s319x unlock problem zeeshan tayyab Infinity-Box 4 03-26-2009 07:46
Page generated in 0.25761 seconds with 11 queries
