05-02-2009, 18:15 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: morocco Age: 39
Member: 243158 Status: Offline Thanks Meter: 25 | alcatel s320 blue screen after unlock blue screen |
05-26-2009, 17:21 | #5 (permalink) |
Product Supporter Join Date: Sep 2001 Location: India
Member: 6109 Status: Offline Sonork: 100.37432 Thanks Meter: 3,781 | Flash with S320X-2CRGTE1_XH16DD32_JRD23_07A_PCB01_GPRS_MT6223_S00.M AUI_07A_W07_36_SP1_V20_2008-12-11_En_Fr_Es_Pt_It.B0M You will get lcd back but still locked. |
The Following User Says Thank You to mobileclinic For This Useful Post: |
07-24-2009, 06:44 | #8 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Madagascar
Member: 233142 Status: Offline Sonork: 100.1595099 Thanks Meter: 527 | here is solution Hi all OT S320 with screen after unlock Flash it with 280X simfree all will OK Code: ALCATEL OT-S320 16U 2BAH 199JS S320X-2POTFA1 352395026228575 COM4 [VCP0] selected module v2.82 Device: Alcatel-S320X Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active "format ffs" active write: Firmware S320X-2AKPNL1-16E_XH16AB12_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP1_V20_2008-06-20_En_Fr_Es_It_De_simfree.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:1A26:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 05 ver. sw 1: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP1_V20.BIN ver. sw 2: MAUI.07A.W07.36.SP1.V20, 00000000 ffs offset/size: 00C00000/00400000 ffs address assigned: 00C00000 detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: enabled Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... security area (code #1) check... security area (code #1) fixed file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S320X_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP1_V20__system_log__FFFFFFFF_20090723-121804.B0X.bin Area: Firmware flash: 98000300000001:2AEA0000000000 Write: Firmware detect device identification#2... detection phase #1... detect device identification#2 finished security area (code #3, part #2) calculation... customization: CH16AB12 done flash: 98000300000001:2AEA0000000000 flash: 98000300000001:2AEA0000000000 Write: security area (code #3, part #2) security area (code #3, part #2) calculation done security area (code #3, part #1) calculation... use default security area (code #3, part #1) pattern ..................security area (code #3, part #1) detecting size... security area (code #3, part #1) detecting parameters... security area (code #3, part #1) encoding... done flash: 98000300000001:2AEA0000000000 flash: 98000300000001:2AEA0000000000 Write: security area (code #3, part #1) security area (code #3, part #1) calculation done Write Done Finalization ... formatting... flash: 98000300000001:2AEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S320X_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP1_V20__system_log__FFFFFFFF_20090723-122641.B0X.bin Finished, time used: 536 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! COM4 [VCP0] selected module v2.82 Device: Alcatel-280X Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active "format ffs" active write: Firmware 280X-2AALFR1-681_XH68WQ03_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP1_V25_2009-02-12_En_Fr_Es_It_De_simfree.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:1A26:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 05 ver. sw 1: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP1_V20.BIN ver. sw 2: MAUI.07A.W07.36.SP1.V20, 00000000 ffs offset/size: 00C00000/00400000 ffs address assigned: 00C00000 detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: disabled Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... security area (code #1) check... security area (code #1) fixed file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-280X_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP1_V20__system_log__FFFFFFFF_20090723-123407.B0X.bin Area: Firmware flash: 98000300000001:2AEA0000000000 Write: Firmware detect device identification#2... detection phase #1... detect device identification#2 finished security area (code #3, part #2) calculation... customization: CH68WQ03 done flash: 98000300000001:2AEA0000000000 flash: 98000300000001:2AEA0000000000 Write: security area (code #3, part #2) security area (code #3, part #2) calculation done security area (code #3, part #1) calculation... use default security area (code #3, part #1) pattern ..................security area (code #3, part #1) detecting size... security area (code #3, part #1) detecting parameters... security area (code #3, part #1) encoding... done flash: 98000300000001:2AEA0000000000 flash: 98000300000001:2AEA0000000000 Write: security area (code #3, part #1) security area (code #3, part #1) calculation done Write Done Finalization ... formatting... flash: 98000300000001:2AEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-280X_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP1_V20__system_log__FFFFFFFF_20090723-124357.B0X.bin Finished, time used: 607 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following 4 Users Say Thank You to said4 For This Useful Post: |
08-03-2009, 18:49 | #9 (permalink) | |
No Life Poster Join Date: May 2005 Location: CANADA Age: 42
Member: 149415 Status: Offline Sonork: 100.1609895 Thanks Meter: 77 | Quote:
08-04-2009, 17:10 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, I think you can try to use the next files: S321X-2ATLES1-328_XH32ZZ82_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_ 07A_W07_36_SP1_V20_2008-12-02_En_Cn_Cn_simfree.B0M.bin 280X-2AALFR1-681_XH68WQ03_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_ 07A_W07_36_SP1_V25_2009-02-12_En_Fr_Es_It_De_simfree.B0M.bin 280X-2AALRU1-681_XH68WJ02_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_ 07A_W07_36_SP1_V25_2009-02-12_En_De_Ru_Bg_Ua_simfree.B0M.bin 280X-2AALLY1-681_XH68WM01_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_ 07A_W07_36_SP1_V25_2009-02-12_En_Fr_Tr_Ar_simfree.B0M.bin |
08-05-2009, 10:40 | #11 (permalink) | |
I try with "S321X-2ATLES1-328_XH32ZZ82_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_ 07A_W07_36_SP1_V20_2008-12-02_En_Cn_Cn_simfree.B0M.bin" all ok but no arabic and french language with 280X-2AALFR1-681_XH68WQ03_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_ 07A_W07_36_SP1_V25_2009-02-12_En_Fr_Es_It_De_simfree.B0M.bin 280X-2AALRU1-681_XH68WJ02_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_ 07A_W07_36_SP1_V25_2009-02-12_En_De_Ru_Bg_Ua_simfree.B0M.bin 280X-2AALLY1-681_XH68WM01_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_ 07A_W07_36_SP1_V25_2009-02-12_En_Fr_Tr_Ar_simfree.B0M.bin[/QUOTE] phone still locked | |
08-16-2009, 15:55 | #14 (permalink) |
No Life Poster Join Date: Nov 2005 Location: ABouSHaDy Age: 48
Member: 200717 Status: Offline Sonork: 100.1580056 Thanks Meter: 793 | to all user just flash u phone with firmware s319a or s319x S319A-2AALUS1-16T_XH16GF32_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_ 07A_W07_36_SP1_V20_2009-02-04_En_Fr_Es_It_En-US_simfree.B0M.bin u problem resolved br ABOUSHADY |
The Following 2 Users Say Thank You to ABOUSHADY For This Useful Post: |
09-03-2009, 11:07 | #15 (permalink) |
Freak Poster Join Date: Mar 2004 Location: at home
Member: 56735 Status: Offline Thanks Meter: 35 | [QUOTE='W][e][R;4754682']to all user just flash u phone with firmware s319a or s319x S319A-2AALUS1-16T_XH16GF32_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_ 07A_W07_36_SP1_V20_2009-02-04_En_Fr_Es_It_En-US_simfree.B0M.bin u problem resolved i flash with this flash file pone unlocked but no network i flash with s320 flash file sim free but always locked i flash with ot 280 and always locked please any solution how to unlock this phoen tnx |
alcatel s621x blue screen after unlock | ogiuwa | Infinity-Box | 8 | 06-30-2009 13:00 |
Alcatel s520x blue screen after flash | jonel1983 | Infinity-Box | 3 | 06-03-2009 06:33 |
alcatel s320 blue screen after read code plz ::: ANSWERED ::: | ksm_lovers2000 | PolarBox 3 | 3 | 03-02-2009 10:02 |
M55 v11 blue screen after unlocking | sonkar | E-Gold Based Phones | 19 | 03-29-2004 21:48 |
M55 v11 blue screen after unlock | moustafatch | E-Gold Based Phones | 6 | 03-03-2004 01:04 |
