Alcatel s520 unlock sucessfully Hi infinity team and members alcatel ot-s520 unlock sucessfully with infinity via flash patch here is the log thanks infinity for the good work and free support COM20 [VCP0] selected Device: Alcatel-OT-S520 Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 chip: 0001:6A03:A006 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22442200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000 0004x008000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: N:\Program Files\InfinityBox\MModule\backup_security\id.0F420 3CB.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN_082778DF].rpl identification#1 detection finished device-id: 0F4203CB identification#1 protocol ver: 05 ver. sw1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN ver. sw2: MAUI.06B.W07.28.SP1.V34, 2087D8F7 ffs offset/size: 00C00000/00400000 detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: disabled Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... original imei: 35198902012199 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... security area (code #1) calculation... done file saved: N:\Program Files\InfinityBox\MModule\backup_security\system_l og_0F4203CB_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34.BIN_082778DF_20081014-084334.B0X.bin Area: Firmware flash: 01227E22442200:18E59F00000000 Write: Firmware detect device identification#2... detection phase #1... detect device identification#2 finished security area (code #3, part #2) calculation... customization: CD44BM01 done flash: 01227E22442200:18E59F00000000 flash: 01227E22442200:18E59F00000000 Write: security area (code #3, part #2) security area (code #3, part #2) calculation done security area (code #3, part #1) calculation... ..................done flash: 01227E22442200:18E59F00000000 flash: 01227E22442200:18E59F00000000 Write: security area (code #3, part #1) security area (code #3, part #1) calculation done Write Done Finalization... Finalization Done file saved: N:\Program Files\InfinityBox\MModule\backup_security\system_l og_0F4203CB_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34.BIN_082778DF_20081014-085344.B0X.bin Finished, time used: 650 sec Remove/Install battery now ! |
Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
Thank man for test report br shahzad |
with which cable pls thanks |
Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout http://www.infinity-box.biz/download...shell_v112.jpg Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
amazing work sir nice info keep it up |
but need pinout perfact 1 thnx for test report sonice of you keep it up i love my infinity box br yasermalik |
