Old 10-14-2008, 15:57   #1 (permalink)
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
Thanks Meter: 6,392
Alcatel s520 unlock sucessfully
Hi infinity team and members
alcatel ot-s520 unlock sucessfully with infinity via flash patch
here is the log
thanks infinity for the good work and free support
COM20 [VCP0] selected
Device: Alcatel-OT-S520
Checking data, wait...
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
Boot...
19200 fixed
Connecting, wait...
Initializing[6225:8A03:8A00]...
CPU: MT6225
chip: 0001:6A03:A006
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 01227E22442200:18E59F00000000
flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000 0004x008000] 16Mb
Initialize Done
Set baud...
460800
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: N:\Program Files\InfinityBox\MModule\backup_security\id.0F420 3CB.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN_082778DF].rpl
identification#1 detection finished
device-id: 0F4203CB
identification#1 protocol ver: 05
ver. sw1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN
ver. sw2: MAUI.06B.W07.28.SP1.V34, 2087D8F7
ffs offset/size: 00C00000/00400000
detect device identification#2...
detect device identification#2 finished
sim-lock status: disabled
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
original imei: 35198902012199
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
security area (code #1) calculation...
done
file saved: N:\Program Files\InfinityBox\MModule\backup_security\system_l og_0F4203CB_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34.BIN_082778DF_20081014-084334.B0X.bin
Area: Firmware
Write: Firmware
security area (code #3, part #2) calculation...
customization: CD44BM01
done
Write: security area (code #3, part #2)
security area (code #3, part #2) calculation done
security area (code #3, part #1) calculation...
..................done
Write: security area (code #3, part #1)
security area (code #3, part #1) calculation done
Write Done
Finalization...
Finalization Done
file saved: N:\Program Files\InfinityBox\MModule\backup_security\system_l og_0F4203CB_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34.BIN_082778DF_20081014-085344.B0X.bin
Finished, time used: 650 sec
Remove/Install battery now !
The Following 5 Users Say Thank You to c_ahmad79 For This Useful Post:
Old 10-14-2008, 16:57   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,234
Thank you very much for test report !
Each test report with attached logs is very important for us so we can see how is Infinity-Box
software works and what is possible problems and successfully done work.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 10-14-2008, 17:11   #3 (permalink)
Member: 515130
Thanks Meter: 304
Thank man for test report
br
shahzad
Old 10-14-2008, 17:17   #4 (permalink)
ATIEFUOR-GSM's Avatar
Member: 132856
Thanks Meter: 36
with which cable pls
thanks
Old 10-14-2008, 17:32   #5 (permalink)
Member: 130995
Here is an instruction how to get cable/pinout information:
1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update
2. run Infinity-Box Shell
3. select required model
4. see detailed information about cable/pinout
Here is information how to build your own cable: http:///vbb/showthread.php?t=342807
Old 10-15-2008, 08:44   #6 (permalink)
GEEBOO's Avatar
Member: 553840
Thanks Meter: 118
amazing work sir nice info keep it up
Old 10-17-2008, 15:42   #7 (permalink)
yasermalik's Avatar
Member: 488632
Thanks Meter: 390
but need pinout perfact 1 thnx for test report sonice of you keep it up i love my infinity box
br
yasermalik
alcatel s520 unlocking with EASY UNLOCKING? ROUGHNECK Easy-Unlocker 1 10-29-2008 13:42
alcatel s520 unlocking error tajinder Infinity-Box 1 10-22-2008 14:39
Alcatel s520 unlocking djouaka PolarBox 3 3 10-22-2008 00:01
Alcatel S520 Unlocking Problem Qaisar Mahmood Infinity-Box 4 10-17-2008 15:58
Page generated in 0.30396 seconds with 8 queries
