02-17-2009, 08:59 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 45
Member: 139388 Status: Offline Thanks Meter: 98 | alcatel S621 dead after flash Here the log COM4 [VCP0] selected Device: Aiko 17G Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 chip: 0001:3003:A00C boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22422200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.CB088 ABE.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN_647456AF].rpl ==================== New firmware detected: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN - make "Read full flash" operation - send "system_log_..." file to support: [email protected] - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: CB088ABE identification#1 protocol ver: 05 ver. sw1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN ver. sw2: MAUI.06B.W07.28.SP1.V34, 50A98B9B ffs offset/size: 01020000/00FE0000 detect device identification#2... detection phase #1... detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: eeprom[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN]... file saved: C:\Documents and Settings\Cell universe\Desktop\eeprom[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN]_20090217-125042.B0E.bin Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_CB088ABE_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34.BIN_647456AF_20090217-125050.B0X.bin Area: Firmware flash: 01227E22422200:18E59F00000000 Write: Firmware detect device identification#2... detection phase #1... detect device identification#2 finished security area#3 calculation... error: can't detect security area#3 version Write Done Finalization... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_CB088ABE_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34.BIN_647456AF_20090217-131940.B0X.bin Finished, time used: 1856 sec Remove/Install battery now ! |
02-17-2009, 09:26 | #4 (permalink) |
No Life Poster Join Date: Apr 2007 Location: BIRMINGHAM UNITED KINGDOM Age: 34
Member: 488632 Status: Offline Thanks Meter: 391 | 1ST FLASH UR FONE WITH THIS FLASH FILE S621X-2AALAP1_XD54BM02_JRD25_06B_PCB01_GPRS_MT6225_S00[1].MAUI_06B_W07_28_SP1_V34_2008-07-22_En_Fr_Tr_Ar_simfree.B0M ND FOLLOW THESE STEPS How to flash: 1. Make full flash backup before any operation for emergency case ! 2. Select firmware that you want and write flash 3. If phone can't power-on after flashing flash it again: . be sure that "Smart write option is checked in "Flash" page . be sure that "Fix security area" option is checked in "Settings" page . be sure that "Enhanced security fix method" option is checked in "Settings" page 4. If phone can't Power-On make "Format ffs" in "complete" mode 5. Press and hold phone "Power" button for a long time (up to 1-2 min) to make phone Powered-On after flash/format After flash process: Power-On and Power-Off phone 4-5 times to be sure that everything is Ok. IF FONE STILL DEAD MAKE ''repair security area '' IN SERVICE TAB UR FONE WILL ALIVE TESTED BY ME BR YASERMALIK DNT FORGET THANKS THNKS INFINITY TEAM |
02-17-2009, 09:34 | #5 (permalink) |
Member: 139388 Status: Offline Thanks Meter: 98 | Format Complete mode done successfully but still phone dead Here the log COM4 [VCP0] selected Device: Aiko 17G Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 chip: 0001:3003:A00C boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22422200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is damaged, recalculation required identification#1 detection finished device-id: CB088ABE identification#1 protocol ver: 05 ver. sw1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN ver. sw2: MAUI.06B.W07.28.SP1.V34, 5FB665DF ffs offset/size: 01020000/00FE0000 detect device identification#2... detection phase #1... detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: eeprom[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN]... file saved: F:\alcatel\eeprom[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN]_20090217-140149.B0E.bin flash: 01227E22422200:18E59F00000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: 01227E22422200:18E59F00000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_CB088ABE_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34.BIN_209A49A0_20090217-140215.B0X.bin Finished, time used: 129 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
02-17-2009, 09:51 | #6 (permalink) | |
Select correct model and flash phone again | |
alcatel s621 dead after flash | gily1 | Infinity-Box | 4 | 07-15-2009 20:35 |
Alcatel E805X dead after flashing | yotamui | Alcatel TCL Phones and New Models | 12 | 07-23-2008 18:29 |
Alcatel OT152 Dead after flashed | my7010107 | Infinity-Box | 11 | 12-17-2007 16:54 |
alcatel E259x dead after flashing!!!. plz help | abumu3ed | FuriousGold | 3 | 07-07-2007 13:23 |
alcatel bg31g dead after flashing | skorn | BF, BG, TH, BHx Series | 5 | 07-05-2005 07:48 |
