03-07-2009, 15:09 | #1 (permalink) |
Freak Poster Join Date: May 2006
Member: 272137 Status: Offline Thanks Meter: 75 | ALCATEL s621x blank screen after unlock HELP COM14 [VCP5] selected module v2.58 Device: Alcatel-S621X Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active "format ffs" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 chip: 0001:3E03:A00D boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22422200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.FAC8E 93E.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN_3439DEED].rpl New firmware detected (2.58) : JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN - make "Read full flash" operation - send "system_log_..." file to support: [email protected] - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) identification#1 detection finished device-id: FAC8E93E identification#1 protocol ver: 05 ver. sw 1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN ver. sw 2: MAUI.06B.W07.28.SP1.V34, 1221C6CB ffs offset/size: 01020000/00FE0000 detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: enabled Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... original imei: 35199002086379 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... security area (code #1) calculation... done file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_FAC8E93E_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34.BIN_3439DEED_20090306-203407.B0X.bin Area: Firmware flash: 01227E22422200:18E59F00000000 Write: Firmware detect device identification#2... detection phase #1... detect device identification#2 finished security area (code #3, part #2) calculation... customization: CD54BM02 done flash: 01227E22422200:18E59F00000000 flash: 01227E22422200:18E59F00000000 Write: security area (code #3, part #2) security area (code #3, part #2) calculation done security area (code #3, part #1) calculation... use default security area (code #3, part #1) pattern error: can't assign default pattern error: can't calculate security area (code #3, part #1) Write Done Finalization ... formatting... flash: 01227E22422200:18E59F00000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_FAC8E93E_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34.BIN_3439DEED_20090306-210353.B0X.bin Finished, time used: 1823 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
03-07-2009, 16:50 | #3 (permalink) | |
Member: 272137 Status: Offline Thanks Meter: 75 | Quote:
its nt a e227 phone,we have to flash this phone with patched firmware,anywy problem shorted flash phone with this S621X-2ATBMK1_XD55DB40_JRD25_06B_PCB01_GPRS_MT6225_S00[1].MAUI_06B_W07_28_SP1_V34_2008-10-31_En_Srpski_Bg_Shqip_T-Mobile.B0M | |
03-13-2009, 13:38 | #4 (permalink) | |
No Life Poster Join Date: Apr 2005 Age: 45
Member: 132856 Status: Offline Thanks Meter: 36 | Quote:
were u able to unlock the phone after? if yes then share it here pls thanks | |
03-13-2009, 18:36 | #5 (permalink) | |
read faq for those phone unlocking.might u ddnt read properly i done lots of s621 unlocking with simfree flash file,but sum are not done newer vesion,when we try to flash with those fone,fone are unlock done but screen cums blank,so at the moment its not support new versions,after if phone goes blank then they are cuming back with this file. S621X-2ATBMK1_XD55DB40_JRD25_06B_PCB01_GPRS_MT6225_S00[1].MAUI_06B_W07_28_SP1_V34_2008-10-31_En_Srpski_Bg_Shqip_T-Mobile.B0M | |
03-14-2009, 13:54 | #6 (permalink) |
No Life Poster Join Date: Apr 2007 Location: BIRMINGHAM UNITED KINGDOM Age: 34
Member: 488632 Status: Offline Thanks Meter: 391 | hi i flashed fone nd fone gave me error new firmware decdect i flash fone with these firmware from support S621X-2AALAP1_XD54BM02_JRD25_06B_PCB01_GPRS_MT6225_S00[1].MAUI_06B_W07_28_SP1_V34_2008-07-22_En_Fr_Serbian_simfree.B0M S621X-2AALAP1_XD54BM02_JRD25_06B_PCB01_GPRS_MT6225_S00[1].MAUI_06B_W07_28_SP1_V34_2008-07-22_En_Fr_Tr_Ar_simfree.B0M S621X-2ATBHR1_XD54CS03_JRD25_06B_PCB01_GPRS_MT6225_S00[1].MAUI_06B_W07_28_SP1_V34_2008-07-22_En_Srpski_De_Hr_Slovencina.B0M S621X-2ATBHR1_XD54CS03_JRD25_06B_PCB01_GPRS_MT6225_S00[1].MAUI_06B_W07_28_SP1_V34_2008-07-22_En_Srpski_De_Hrvatski_Slovencina_T-Mobile.B0M S621X-2AVRGB1_XD54CW08_JRD25_06B_PCB01_GPRS_MT6225_S00[1].MAUI_06B_W07_28_SP1_V34_2008-08-06_En_Fr_Es_It_De_Virgin.B0M fone start ok but screen blank any good saloution br yasermalik plz infinity tean give me a good saloution |
03-14-2009, 14:16 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Did you tried to flash phone with this firmware ? S621X-2ATBMK1_XD55DB40_JRD25_06B_PCB01_GPRS_MT6225_S00.M AUI_06B_W07_28_SP1_V34_2008-10-31_En_Srpski_Bg_Shqip_T-Mobile |
03-14-2009, 17:26 | #8 (permalink) |
Member: 488632 Status: Offline Thanks Meter: 391 | flashed fone with recommended flash file after flash formate in complete bt still same COM123 [VCP0] selected module v2.65 Device: Alcatel-S621X, S621A Checking data, wait... advanced flash detection enabled Action: "format ffs" enhanced security fix enabled Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 chip: 0001:5703:A008 status: 01 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22422200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.ED72C 66A.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN_209A49A0].rpl identification#1 detection finished device-id: ED72C66A identification#1 protocol ver: 05 ver. sw 1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN ver. sw 2: MAUI.06B.W07.28.SP1.V34, 5FB665DF ffs offset/size: 01020000/00FE0000 detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: enabled Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... original imei: 35199002052500 flash: 01227E22422200:18E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 01227E22422200:18E59F00000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_ED72C66A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34.BIN_209A49A0_20090314-092327.B0X.bin Finished, time used: 130 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! changed pc used old mouddle but same plz infinity box ggive a perfact saloution br yasermalik |
03-14-2009, 17:39 | #10 (permalink) |
Member: 488632 Status: Offline Thanks Meter: 391 | sir b4 i flashed fone with all flashing using my other pc now im @ home nd using different pc now it doesn't say new firmware detected same mean its in blue screen like b4 after flashing the fone was working ok b4 was pack in box plz plz sir give me a good working saloution like orignal flash file it was on virgin mobile r give me new simfree flash file r any other saloution like formate whole chip thanks alot nd plz i need saloution 2day thanks again br yasermalik |
03-14-2009, 17:59 | #12 (permalink) |
Member: 488632 Status: Offline Thanks Meter: 391 | look like new type on lcd i already solved this problem on sagem my220x was in blue screen after flashing then i flashed fone with vodafone 226 flash file 100% done on F GOLD PLZ PLZ ANY SALOUTION BR YASERMALIK THANKS INFINITY TEAM BEST TOOL WITH GOOD SUPPORT Last edited by yasermalik; 03-14-2009 at 18:01. Reason: MORE |
03-16-2009, 02:02 | #14 (permalink) | |
Freak Poster Join Date: Jan 2002 Location: www.GSMAlleyWay.org Age: 60
Member: 8300 Status: Offline Thanks Meter: 51 | Hi Quote:
Whats strange I have same problem with S319x which was flashed too, it accepts all types of flash files but no display. Eventhough I have sent the flash file to infinity but no reply yet. I think one of greatly supported boxes on the market must be on holiday otherwise there would have been a reply and an update soon. I hope you are coming back soon, please. Thank you Regards | |
The Following User Says Thank You to GSMAlleyWay For This Useful Post: |
03-16-2009, 14:44 | #15 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, I do not expect fast answer for these questions but anyway: 1. What holidays you talk about ? 2. What do you think, how many time it is need to create any solution or update software ? 3. When and where you have sent your files ? One more question, I expect urgent reply to this question, it's more easy question that previous questions: 4. What files you have used for flashing ? Post here file names. @yasermalik 5. What do you mean "where r product supporter" ? 6. What is your problem for now ? Damaged or locked phone ? What is the problem exactly ? Btw, if you can, please, make an answers for first two questions from my message. |
Alcatel S621X No Screen after Unlock | drancill | Infinity-Box | 7 | 02-19-2012 14:11 |
Alcatel s621x blue lcd after unlock..... | multicom_fsdpk | Infinity-Box | 6 | 09-13-2009 11:47 |
Alcatel s621x blue lcd after unlock..... | multicom_fsdpk | Infinity-Box | 2 | 08-18-2009 20:26 |
alcatel s621x blue screen after unlock | ogiuwa | Infinity-Box | 8 | 06-30-2009 13:00 |
