01-10-2009, 09:34 | #1 (permalink) |
Freak Poster Join Date: Mar 2006
Member: 239985 Status: Offline Thanks Meter: 28 | alcatel s621x unlock successful file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_6D78C6DF_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34.BIN_26DFC24B_20090110-135214.B0X.bin Area: Firmware flash: 01227E22422200:18E59F00000000 Write: Firmware detect device identification#2... detection phase #1... detect device identification#2 finished security area (code #3, part #2) calculation... customization: CD54BM02 done flash: 01227E22422200:18E59F00000000 flash: 01227E22422200:18E59F00000000 Write: security area (code #3, part #2) security area (code #3, part #2) calculation done security area (code #3, part #1) calculation... ..................security area (code #3, part #1) detecting size... security area (code #3, part #1) detecting parameters... security area (code #3, part #1) encoding... done flash: 01227E22422200:18E59F00000000 flash: 01227E22422200:18E59F00000000 Write: security area (code #3, part #1) security area (code #3, part #1) calculation done Write Done Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_6D78C6DF_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34.BIN_26DFC24B_20090110-142331.B0X.bin Finished, time used: 1914 sec Remove/Install battery now ! enjoy |
The Following User Says Thank You to mustafegur1 For This Useful Post: |
01-10-2009, 18:20 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
01-26-2009, 11:08 | #3 (permalink) |
Insane Poster Join Date: Feb 2006 Location: Zemun Srbija
Member: 231752 Status: Offline Thanks Meter: 14 | S621x unlock ok ytx to infinity COM4 [VCP0] selected module v2.61 Device: Alcatel-S621X Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 chip: 0001:0C03:A00F boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22422200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.58A0A C2F.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN_209A49A0].rpl identification#1 detection finished device-id: 58A0AC2F identification#1 protocol ver: 05 ver. sw 1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN ver. sw 2: MAUI.06B.W07.28.SP1.V34, 5FB665DF ffs offset/size: 01020000/00FE0000 detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: enabled Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... original imei: 35199002021711 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... security area (code #1) calculation... done file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_58A0AC2F_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34.BIN_209A49A0_20090126-104054.B0X.bin Area: Firmware flash: 01227E22422200:18E59F00000000 Write: Firmware detect device identification#2... detection phase #1... detect device identification#2 finished security area (code #3, part #2) calculation... customization: CD54BM02 done flash: 01227E22422200:18E59F00000000 flash: 01227E22422200:18E59F00000000 Write: security area (code #3, part #2) security area (code #3, part #2) calculation done security area (code #3, part #1) calculation... ..................security area (code #3, part #1) detecting size... security area (code #3, part #1) detecting parameters... security area (code #3, part #1) encoding... done flash: 01227E22422200:18E59F00000000 flash: 01227E22422200:18E59F00000000 Write: security area (code #3, part #1) security area (code #3, part #1) calculation done Write Done Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_58A0AC2F_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34.BIN_209A49A0_20090126-105139.B0X.bin Finished, time used: 682 sec Remove/Install battery now ! |
The Following User Says Thank You to Munze konza For This Useful Post: |
07-29-2009, 08:20 | #7 (permalink) |
Freak Poster Join Date: Aug 2007 Location: Pakistan
Member: 559810 Status: Offline Sonork: Not use Thanks Meter: 176 | Salam ----- bro when i click the SP Unlock then give me this msg " Read manual from support areaand flash phone with special firmware lucky121 |
07-29-2009, 08:22 | #8 (permalink) |
07-29-2009, 10:04 | #9 (permalink) |
No Life Poster Join Date: May 2007 Location: InsidE AndroiD Age: 37
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | bro its only possible with simfree firmware.. u hav to flash it with the firmware given at support ... read post no.1 flash it with S621X-2AALAP1_XD54BM02_JRD25_06B_PCB01_GPRS_MT6225_S00.M AUI_06B_W07_28_SP1_V34_2008-07-22_En_Fr_Tr_Ar_simfree.B0M |
Alcatel S621X Unlock Successful | Colin | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 8 | 09-16-2009 13:43 |
lobster s621, alcatel s621x unlocked with 100% success | Umair Rashid | Infinity-Box | 9 | 04-04-2009 12:53 |
alcatel s621x unlock successful | naeem janjua | Infinity-Box | 0 | 03-16-2009 15:27 |
Alcatel S621X unlock | scebic | Infinity-Box | 6 | 02-04-2009 20:46 |
Alcatel s621x unlock sucessfully full method here | c_ahmad79 | Infinity-Box | 2 | 02-01-2009 14:13 |
