02-27-2019, 17:18 | #1 (permalink) |
Freak Poster Join Date: Dec 2015 Location: GREAT YAR*****
Member: 2495115 Status: Offline Thanks Meter: 34 | frp remove XT 1622 I received this Motorola XT 1622 for FRP remove Operation : Identify [ v1.03 ] Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! Main Info ============ CPU : MSM8952 CID : 0x0032 IMEI : 354122070554294 UID : 9CB5BB0000000000000000000000 Model Info ============ DevModel : XT1622 IntName : athene_13mp SW Info ============ DevSWVer : Blur_Version.25.231.5.athene.retail.en.US DevQCVer : LA.BR.1.3.6-01710-8976.0 BaseBand : M8952_70030.25.03.62.02R ATHENE_EMEA_CUST BootLDRv : moto-msm8952-B1.07 HW Info ============ eMMCInfo : 16GB SAMSUNG QE13MB RV=08 PV=07 FV=0000000000000007 DRAMInfo : 2GB SAMSUNG LP3 DIE=8Gb M5=01 M6=05 M7=00 M8=1F Lock Info ============ WarrantyVoid : no FRP Lock : protected (77) Done! Operation : Moto ADB Enable [ v1.03 ] Mode : Enable ADB Waiting for NetInterface arrival ... 1. Power off device. Press and hold 'VOL DOWN' and 'POWER ON' buttons 2. Select by 'VOL DOWN' or 'VOL UP' FACTORY MODE , press 'POWER ON' 3. Connect USB cable, when device boot complete! Device not found! Check cable, drivers and conection! Tried two different laptops and cables, is this a driver problem? which driver should i use please Thank you Steve |
02-28-2019, 14:24 | #3 (permalink) |
Member: 2495115 Status: Offline Thanks Meter: 34 | Thank you I've enabled factory mode, under Device Manager on my Laptop I find two connections 1. Moto G (4) 2. Unknown device Both connections have Exclamation marks, I assume there is something wrong with drivers, Does any one know where I can obtain the correct drivers from please Thank you Steve |
03-06-2019, 12:50 | #4 (permalink) |
Member: 2495115 Status: Offline Thanks Meter: 34 | Today I found Motorola End User Driver Installation. I beleive these are the drivers I need for this Motorola? I cannot istal these drivers on my W10 machine? I cannot seem to find any drivers for this phone to run on w10? Any help /advice gratefully received Thank you Steve |
