01-14-2009, 15:03 | #1 (permalink) |
Freak Poster Join Date: Jan 2006 Location: colombia Age: 45
Member: 220008 Status: Offline Thanks Meter: 95 | Alcatel V770 unlock after flash on the screen without image |
01-14-2009, 19:46 | #2 (permalink) | |
I did not understand the problem well, anyway, here is an advice: try to use other firmware file for flashing and try to make "format ffs". | |
01-15-2009, 13:48 | #3 (permalink) |
Member: 220008 Status: Offline Thanks Meter: 95 | The problem I have is this friend to try to unlock a V770 with flash support simfree said that it will run out of image display flash down all the support and enter one by one and nothing remains the same try to do with the 2.49 mm module to the latest version is 2.60 and is still with the same problem to see if I can help this is the problem greetings |
01-15-2009, 13:52 | #4 (permalink) |
Member: 220008 Status: Offline Thanks Meter: 95 | Also try to make format ffs several times with different versions of the module mmodulo and the same image without the display and the team was doing before image on the display to please assist me greetings |
01-15-2009, 23:27 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Did you tried to flash phone with different flash files ? What files you have used ? Do you see any errors during flash or unlock operations ? |
01-16-2009, 15:06 | #6 (permalink) |
Member: 220008 Status: Offline Thanks Meter: 95 | I have not had any problems when entering any of the flash of the income support is no problem when the problem is not what I turn I get the image to read the screen just like a flash in the same company to put in the porfavor support and thus able to solve my problem greetings |
01-16-2009, 15:11 | #7 (permalink) |
01-16-2009, 15:33 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, write exact answers for the next questions: 1. Did you tried to flash phone with different flash files ? 2. What files you have used ? 3. Do you see any errors during flash or unlock operations ? Please, attach here photo of phone with error message etc. due to we are unable to understand the problem well yet. |
01-17-2009, 17:24 | #9 (permalink) |
Member: 220008 Status: Offline Thanks Meter: 95 | 1 all flash media are in total there are 4 on the stand 2 I used the 4 files that are in support and none has left any error during operation 3 After joining the team any of the flash that are in support but leaves encinede screen image |
01-17-2009, 17:31 | #10 (permalink) |
Member: 220008 Status: Offline Thanks Meter: 95 | This operation is the log of the team and will see that it is not error algunon for me is that this is a new version and it is no image on the screen comes out greetings español ==== log: [2009-01-14 13:24:16] ==== COM6 [VCP0] selected modulo v2.49 Servicio: Alcatel-OT-V770X, V770A Checkeando datos, espere... Habilitada la deteccion avanzada del chip Accion: Escribir NOR flash Escribir: Firmware saltar: Customization/Language Pack saltar: Customization saltar: Eeprom/ffs Boot ... Mantenga Presionado el boton Power ! 19200 fixed Conectando, espere... Iniciando [6219:8B03:8B02]... CPU: MT6219 detected CPU: MT6226MA chip: 0031:6DA7:A000 Tamaño del boot packet: 0400 Deje de presionar el boton power ahora ! Boot Done Iniciar ... detecting chip #00 in region #00... flash: 01227E22302200:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb numero de flash chip/regiones detectadas: 01/01 Iniciar Done Seleccionar velocidad ... 921600 Seleccionar velocidad Done Iniciar bootcode ... Iniciar bootcode Done Comprobar la integridad del firmware ... detect device identification#1... fase de deteccion #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.4A 9905FD.[JRD26_06A_PCB01_GPRS_MT6226M_S02.MAUI_06A_W06_52_S P1_V31.BIN_9B8A0357].rpl identification#1 detection finished device-id: 4A9905FD identification#1 protocol ver: 05 ver. sw 1: JRD26_06A_PCB01_GPRS_MT6226M_S02.MAUI_06A_W06_52_S P1_V31.BIN ver. sw 2: MAUI.06A.W06.52.SP1.V31, A8FC7564 ffs offset/size: 01000000/01000000 detect device identification#2... fase de deteccion #1... detect device identification#2 finished Estado sim-lock: enabled Comprobar la integridad del firmware Done Comprobar el contenido del firmware ... Comprobar el contenido del firmware Done Backup de datos requeridos ... Imei original: 01143200061352 Backup de datos requeridos Done Revisión de datos requeridos ... Revisión de datos requeridos Done Operacion Especial ... Operacion Especial Done Escribir ... security area (code #1) calculation... Listo Archivo guardado: C:\Archivos de programa\InfinityBox\MModule\backup_security\syste m_log_4A9905FD_JRD26_06A_PCB01_GPRS_MT6226M_S02.MA UI_06A_W06_52_SP1_V31.BIN_9B8A0357_20090114-132609.B0X.bin Area: Firmware flash: 01227E22302200:2BEA0000000000 Escribir: Firmware detect device identification#2... fase de deteccion #1... detect device identification#2 finished security area (code #3, part #2) calculation... customization: CG22GD6E Listo flash: 01227E22302200:2BEA0000000000 flash: 01227E22302200:2BEA0000000000 Escribir: security area (code #3, part #2) security area (code #3, part #2) calculation done security area (code #3, part #1) calculation... ..................Listo flash: 01227E22302200:2BEA0000000000 flash: 01227E22302200:2BEA0000000000 Escribir: security area (code #3, part #1) security area (code #3, part #1) calculation done Escribir Done Finalizado ... Finalizado Done Archivo guardado: C:\Archivos de programa\InfinityBox\MModule\backup_security\syste m_log_4A9905FD_JRD26_06A_PCB01_GPRS_MT6226M_S02.MA UI_06A_W06_52_SP1_V31.BIN_9B8A0357_20090114-133605.B0X.bin Finalizado, tiempo usado: 696 sec Quite/coloque la bateria ahora ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! |
01-17-2009, 18:36 | #11 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Do you have similar good working phone ? If yes, please, read flash from it and send full flash backup to [email protected] |
01-19-2009, 15:33 | #12 (permalink) |
Member: 220008 Status: Offline Thanks Meter: 95 | hello today sent two reading a flash of an Alcatel V770 operator Digitel to resolve a power like I have no image on the display after entering simfree flash media to please the media and put in order retrieve him and another team is a alcatel n5 GlamPhone that she died when entering n5 flash it to support for this model and can handle well the power recueperar for more flash ellen5 elle n3 expect prompt response greetings http://www.4shared.com/file/81418932...a_soporte.html http://www.4shared.com/file/79790296...lle_el05a.html |
01-19-2009, 15:36 | #13 (permalink) |
Member: 220008 Status: Offline Thanks Meter: 95 | flash reading for supporting these versions greetings hello today sent two reading a flash of an Alcatel V770 operator Digitel to resolve a power like I have no image on the display after entering simfree flash media to please the media and put in order retrieve him and another team is a alcatel n5 GlamPhone that she died when entering n5 flash it to support for this model and can handle well the power recueperar for more flash ellen5 elle n3 expect prompt response greetings http://www.4shared.com/file/81418932...a_soporte.html http://www.4shared.com/file/79790296...lle_el05a.html |
01-19-2009, 20:58 | #14 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, I can not download files by given links. Please, send correct links to [email protected] Thank you ! |
Alcatel V770 unlock flash | Lazy2003 | FuriousGold | 0 | 10-21-2009 13:22 |
7610 after flashing on white screen | pakmobiles | WD2 & APE (Symbian Phones) | 7 | 05-07-2008 17:12 |
D800 after flash with UST2 has brocken image on the screen. | JC_BY | UST Pro II | 10 | 07-09-2006 22:26 |
NOTHING show on the screen after flashing 5110 | MySweetyLove | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 03-13-2002 04:10 |
