11-12-2008, 16:46 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: Georgia
Member: 772384 Status: Offline Thanks Meter: 40 | n95 8g rm-17 it was discussed many times in this forum,but where is pinouts I can not understand,in cpu only gnd and power is marked.please help me |
11-12-2008, 18:01 | #3 (permalink) | |
Freak Poster Join Date: Jan 2006 Location: United States
Member: 223859 Status: Offline Thanks Meter: 35 | Quote:
The cable from your phone is the same mini USB, After connecting the telephone cable select the COM port and install the drivers (6218 Drivers USB MODEM DRIVER) Located in: C:\Program Files\InfinityBox\Drivers\MT6218 I hope I have helped you | |
11-12-2008, 20:29 | #5 (permalink) |
Member: 772384 Status: Offline Thanks Meter: 40 | yes it has usb mini like motorola cabel ,but I NEED rx tx and gnd , the phone not turns on,so by measuring I CAN NOT FIND RX AND TX ,please advice me something |
11-13-2008, 15:29 | #9 (permalink) |
Member: 223859 Status: Offline Thanks Meter: 35 | Excuse me by mistake, but here is the correct and pinning Log's information Phone. COM3 [VCP2] selected module v2.68 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read/check detailed information Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:3E03:0000 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 04227E22212200:18E59F00000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: 04227E22212200:18E59F00000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 04227E22212200:18E59F00000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: 04227E22212200:18E59F00000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: MT25_06B_HW.DS100_AR5_V3_1BTEST--080320.BIN ver. sw 2: DS100_AR5_V3.1BTEST, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 04227E22212200:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF detecting ffs structure pass 1... ...................... detect standard fat location pass #1... .................................................. .. detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #1 detected ok detecting ffs structure pass 2... ...................... detect standard fat location pass #1... .................................................. .. detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #2 detected ok Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Finished, time used: 60 sec Remove/Install battery now ! Remember of THANKS |
11-14-2008, 23:46 | #12 (permalink) |
No Life Poster Join Date: Jan 2005 Location: Land of Lakes and Volcanoes Age: 51
Member: 111014 Status: Offline Thanks Meter: 132 | hello, how can I unlock this phone N95 8G? which cable to use? phone have like mini usb cable connector... phone turn on, when I insert cable... can u help please |
11-15-2008, 01:02 | #13 (permalink) | |
Just use Infinity-Box ChineseMiracle software, you will see "unlock" button in "Service" page. | |
11-15-2008, 16:04 | #14 (permalink) |
Member: 111014 Status: Offline Thanks Meter: 132 | Ok, but which cable to use? Any pinout please? I search forum and I found many thread about this issue, and I am confused, this is the first chinese phone want to try... thanks |
11-15-2008, 20:26 | #15 (permalink) |
Freak Poster Join Date: May 2008
Member: 783324 Status: Offline Thanks Meter: 15 | excuse me infiity team,I opened the phone but test points I never searched in chinese phone,is it a new method or what? I searched only rx tx ,but unfortunetly did not found them |
ineed flash file n95 8g rm-164 arabic | tornado2008 | Infinity-Box | 1 | 08-26-2008 21:58 |
need pinout for n95 8g rm-164 | shawgsm | Infinity-Box | 3 | 08-19-2008 21:13 |
please help my N95 8g rm-17..... | jake007 | SpiderMan | 2 | 05-13-2008 09:38 |
