alfatel h1 white display 1 Attachment(s) cpu mt 6225A, incoming & outing ok see this log is this the h/w or s/w pl. help |
what do u try to do..? format ffs..? |
read "detailed information"...and flash it with same fw...check support for fw.. |
detailed information COM6 [VCP3] selected module v2.77 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check detailed information Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:8E03:0006 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000000:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000000:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #02 in region #00... flash: 98000300000000:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #03 in region #00... flash: 98000300000000:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98000300000000:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000000:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.86F9119C.[HUSCKY4_S27_PCB01_GPRS_MT6225_S00.PN-SC_CN_LLNUMLD_234_YYMMDD_CAM_MCPMCP_O.BIN_F2127411].rpl ==================== New firmware detected (v.2.77, database date: unknown): HUSCKY4_S27_PCB01_GPRS_MT6225_S00.PN-SC_CN_LLNUMLD_234_YYMMDD_CAM_MCPMCP_O.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send "system_log_..." file to support: [email protected] - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: 86F9119C identification#1 protocol ver: 04 ver. sw 1: HUSCKY4_S27_PCB01_GPRS_MT6225_S00.PN-SC_CN_LLNUMLD_234_YYMMDD_CAM_MCPMCP_O.BIN ver. sw 2: PN-SC_CN_LLNUMLD_234_YYMMDD_CAM_MCPMCP_O, EE8BED0D ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 98000300000000:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detecting ffs/eeprom structure pass 1... ......................... detect standard fat location pass #1... .................................................. .. detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs/eeprom detected ok: element #1 detecting ffs/eeprom structure pass 2... ......................... detect standard fat location pass #1... .................................................. .. detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs/eeprom detected ok element #2 Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_86F9119C_HUSCKY4_S27_PCB01_GPRS_MT6225_S 00.PN-SC_CN_LLNUMLD_234_YYMMDD_CAM_MCPMCP_O.BIN_F2127411 _20090222-122923.B0X.bin Finished, time used: 75 sec Remove/Install battery now ! |
ur flash file detail... HUSCKY4_S27_PCB01_GPRS_MT6225_S 00.PN-SC_CN_LLNUMLD_234_YYMMDD_CAM_MCPMCP_O.BIN_F2127411 _20090222-122923.B0X.bin but not exist on support.. |
ffs format?????????????? can i make format ffs??????? |
sure, format FFS is first thing to try make full backup and try first Format FFS safe and continue with Format FFS complete |
can't format ffs???? frist i read full backup & try format ffs this error show show this log COM6 [VCP4] selected module v2.77 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:8E03:0006 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... warning: can't read software version, probably unknown firmware detecting structure #2... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18warning: wrong packet cs 19 20 21 22 23 24 25 26 27error: detection failed (28 tries), read flash and send to support connection lost error: operation failed ! Finished, time used: 14 sec Remove/Install battery now ! finally i send backup flash file to [email protected] |
complete format COM6 [VCP4] selected module v2.77 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:8E03:0006 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000000:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000000:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #02 in region #00... flash: 98000300000000:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #03 in region #00... flash: 98000300000000:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98000300000000:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000000:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.86F9119C.[HUSCKY4_S27_PCB01_GPRS_MT6225_S00.PN-SC_CN_LLNUMLD_234_YYMMDD_CAM_MCPMCP_O.BIN_F2127411].rpl ==================== New firmware detected (v.2.77, database date: unknown): HUSCKY4_S27_PCB01_GPRS_MT6225_S00.PN-SC_CN_LLNUMLD_234_YYMMDD_CAM_MCPMCP_O.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send "system_log_..." file to support: [email protected] - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: 86F9119C identification#1 protocol ver: 04 ver. sw 1: HUSCKY4_S27_PCB01_GPRS_MT6225_S00.PN-SC_CN_LLNUMLD_234_YYMMDD_CAM_MCPMCP_O.BIN ver. sw 2: PN-SC_CN_LLNUMLD_234_YYMMDD_CAM_MCPMCP_O, EE8BED0D ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 98000300000000:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 98000300000000:18E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 98000300000000:18E59F00000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_86F9119C_HUSCKY4_S27_PCB01_GPRS_MT6225_S 00.PN-SC_CN_LLNUMLD_234_YYMMDD_CAM_MCPMCP_O.BIN_F2127411 _20090224-133002.B0X.bin Finished, time used: 84 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! but problem is same |
hello! if format FFS is not helpfull- you must make flashing with good working backup HUSCKY4_S27_PCB01_GPRS_MT6225_S00.PN-SC_CN_LLNUMLD_234_YYMMDD_CAM_MCPMCP_O |
file on support??????????? i got 1 file on support HUSCKY_S02_PCB01_GPRS_MT6225_S00[1].PN-SC_CN_LLNUMLD_229_YYMMDD_CAM_MCPMCP_O__******_16m_ En_Ru_Fr_Pt.B0M i try flash with this file???? |
HUSCKY4_S27_PCB01_GPRS_MT6225_S00.PN-SC_CN_LLNUMLD_234_YYMMDD_CAM_MCPMCP_O.BIN |
flashing error 1 Attachment(s) this error show when flashing |
New flash type, Infinity working on it flash: 98000300000000 search for this and you will find that you cannot write back your backup until support for this flash type is done. |
dead mobile after the error mobile is dead |
