11-03-2009, 06:58 | #3 (permalink) |
Registered User Join Date: Aug 2004 Age: 44
Member: 76882 Status: Offline Thanks Meter: 56 | Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC240200000000:2BEA0000000000 error: detected/calculated [01000000/00010000] chip size mismatch, chip detection failed flash: AMD/Fujitsu std [def 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: EC240200000000:2BEA0000000000 error: detected/calculated [01000000/00010000] chip size mismatch, chip detection failed flash: AMD/Fujitsu std [def 0008x002000 00FFx010000] 16Mb it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [standard] generation ==================== New firmware detected (v.2.90, database date: 21.08.2009): QING_S03_PCB01_GPRS_MT6223P_S00.QING-S03_YR_L6EN_302_090508_CAM010_MCP128+32_BT_FM.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info protocol ver: 05 ver. sw 1: QING_S03_PCB01_GPRS_MT6223P_S00.QING-S03_YR_L6EN_302_090508_CAM010_MCP128+32_BT_FM.BIN ver. sw 2: QING-S03_YR_L6EN_302_090508_CAM010_MCP128+32_BT_FM, 00000000 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC240200000000:2BEA0000000000 error: detected/calculated [01000000/00010000] chip size mismatch, chip detection failed checking area [00000000]: 00000000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detect device sec info... detection phase #1... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: EC240200000000:2BEA0000000000 error: detected/calculated [01000000/00010000] chip size mismatch, chip detection failed Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... ffs formatting... flash: EC240200000000:2BEA0000000000 error: detected/calculated [01000000/00010000] chip size mismatch, chip detection failed error: error# 00002073 error: flash erase error: 00E10000 Finalization Fail Finished, time used: 474 sec Remove/Install battery now ! |
11-08-2009, 10:44 | #5 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Quote:
I was a problem with new type of phone hardware. Please, try to use this software for flashing: http://www.infinity-box.com/download...acle_v2.97.rar It was tested with new flash chip types. Waiting for your results. | |
