Old 07-10-2009, 22:36   #1 (permalink)
lacasapc's Avatar
Member: 259133
Thanks Meter: 22
Thumbs up Lg ke970 flash problem
hi brothers,
i am trying to flash this phone to change the language,
i want spanish in it, but i flashed with KE970P40-07-V10e-000-00_APR-05-2007_firmware_En_Ee_Kz_Lv_Lt_Ru_Ua.B1M irst, but i dont understand to change to spanish with this one,
after that i downloaded this other one KE970P40-ESA-V10f-000-00_MAY-15-2007_En_Vn_firmware.B1M but the same comes the message
"meni" for menu, i dont know what language is this and cant not change it,
here is the last flash log
COM4 [VCP0] selected
module v1.60
Device: LG-KE970
Checking data, wait...
Action: flash write
Boot ...
loading...
next part...
boot answer: 02
Release Power button now
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0089:88B0
Connecting Done
Check hardware ...
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: F:\Archivos de programa\InfinityBox\Pana01\LG-KE970_eeprom-static_20090710-164912.B1E.bin
reading eeprom-static2...
file saved: F:\Archivos de programa\InfinityBox\Pana01\LG-KE970_eeprom-static2_20090710-164912.B1E.bin
loading data...
data loaded
imei: 35030526000000100
reading eeprom-security_35030526000000100...
file saved: F:\Archivos de programa\InfinityBox\Pana01\LG-KE970_eeprom-security_35030526000000100_20090710-164913.B1E.bin
reading eeprom-complete_35030526000000100...
file saved: F:\Archivos de programa\InfinityBox\Pana01\LG-KE970_eeprom-complete_35030526000000100_20090710-164914.B1E.bin
backup critical area Done
Check memory ...
Check memory Done
Write ...
reset...
done
Writing: Firmware
repair write error [A06F4000:0800]...
Ok
Verifying...
Done
Write Done
Finished, time used: 1122 sec
Remove/Install battery now !
Old 07-11-2009, 10:31   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Try to browse menu and find menu with Language option.
Also you can try to use codes http://www.infinity-box.com/wiki/index.php/LG-KG110
and reset phone, so language should be set to English.
Old 07-11-2009, 19:52   #3 (permalink)
lacasapc's Avatar
Member: 259133
Thanks Meter: 22
Originally Posted by InfinitySupport View Post
Hello,
thank you bro, i did reset the phone but still comes that menu in that strange language, i dont know what to do
Old 11-30-2011, 02:02   #4 (permalink)
Member: 1698387
Thanks Meter: 43
Hello Infinty team
I have LG KE970
I have made full flash backup first and than tried to flash it whit an other firmware from support site. In flash process i had problems whit my computer and it made a reboot.
After i fixed the computer and tried to flash phone again it always giving me this error.
Now the phone cannot power on.
Please help me
Thank you
module v1.77
Device: LG-KE970
Action: write flash
write: Firmware
KE970P40FL-48-V10c-260-01_DEC-20-2007+0.B1M.bin
skip: FFS-1/Customization
skip: Language Pack
skip: Graphics Pack
skip: FFS-2/File system
skip: Eeprom
Boot ...
s-gold2: C0
loading...
next part...
error: can't run main loader:
Finished, time used: 6 sec
Old 12-01-2011, 11:04   #5 (permalink)
Member: 1698387
Thanks Meter: 43
Please help infinity team
Old 12-02-2011, 15:06   #6 (permalink)
Member: 1698387
Thanks Meter: 43
Where is the support?
Would anybody please answer! Is this phone can fix whit infinity box or need to buy an other for fixing similar problems?
Old 12-02-2011, 15:06   #7 (permalink)
Member: 1698387
Thanks Meter: 43
Old 12-05-2011, 01:43   #8 (permalink)
Member: 1698387
Thanks Meter: 43
Hello,
Also you can try to use codes Index.php/LG-KG110 - Infinity-Box Knowledge database
Hello
Would you please help me whit this KE970?
OM4 [VCP0] selected
module v1.77
Device: LG-KE970
Action: write flash
write: Firmware
skip: Language Pack
skip: Graphics Pack
skip: Eeprom
Boot ...
s-gold2: C0
loading...
next part...
Old 12-05-2011, 21:10   #9 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
do you keep power button pressed long enough?
battery is charged and it is has more than 3,7volts?
Old 12-06-2011, 23:59   #10 (permalink)
Member: 1698387
Thanks Meter: 43
hello!
Hello
I have tried many times. i did pressed the power button long enough.
The battery has 3.78Volts right now.
Lett me tell you what is the history of this phone.
The phone was working fine before this procedure only had freeze problem when i enter to file manager. I made a format ffs on the phone but problem is not fixed.
After this i have downloaded firmware and eeprom files from server and start to flash it. This time my computer is turn off by a power break at are building.
(before flashing is finished)
Than this problem is came up.
I also have the full flash backup but now the phone is dead and cannot flash it back.
I have searched some of forums and have find that many people has same problem and they did not find any solution.
Would you please help me or do you have any idea what to do?
Thank you
Old 12-08-2011, 13:15   #11 (permalink)
Member: 148515
hello!
at what point flashing was interrupted? in %
in the beginning or in the middle or at the end?
Old 12-08-2011, 16:25   #12 (permalink)
Member: 1698387
Thanks Meter: 43
hello!
Hello
Between 2-5%
Old 12-08-2011, 18:13   #13 (permalink)
Member: 148515
hello!
i will ask programmers if there is some kind of Boot_sector which could get damaged
Old 12-08-2011, 19:30   #14 (permalink)
Member: 1698387
Thanks Meter: 43
hello!
OK.
Please let me know, if you find solution for the problem. Thank you!
Old 12-09-2011, 15:58   #15 (permalink)
Member: 148515
hello!
yes, seems that your phone boot sector is damaged now.
we have some recovery ideas for such cases, will focus on them after will finish with current work
lg LG KE970 KEYPAD PROBLEM oyinkasola LG Hardware Repair 1 07-15-2009 23:42
Fine for LG KE970 Flash Tool and Flash File Khmer GSM LG 1 01-01-2009 11:47
LG-KE970 Flashing Problem JaY'Treze Infinity-Box 17 12-03-2008 17:37
LG KE970 Flash Problem imran_qasim Infinity-Box 3 08-29-2008 19:20
lg KE970 unlock problem oss001 LG 1 12-24-2007 12:48
Page generated in 0.32563 seconds with 10 queries
