-   Infinity-Box (http://forum.gsmhosting.com/vbb/f296/)
-   -   alkatel ot-355dx unlock done with infinity (http://forum.gsmhosting.com/vbb/f296/alkatel-ot-355dx-unlock-done-infinity-1433957/)
dbarakov 02-25-2012 10:43
now ot-355dx unlock with infinity only pres "repair blocket by network" enter imei N:1 and pres buton 10X infinity
MModule 4.12 :):):)
COM13 [VCP1] selected
module v4.12
Device: Alcatel-355DX, 355DA
Checking data, wait...
Action: "repair imei"
new imei: 350724302577243
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A08]...
CPU: MT6223
high speed boot On
chip: 0011:B456:A00C
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: EC240200000000:2BEA0000000000
flash: Samsung K5L2833ATA T 16Mb
otp offset: 00FF0000
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
interesting cpu type found
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [protected] type (05), 1 record(s)
TCL-ID is present
startup code area #1 is Ok
startup code area #1 backup saved: c:\InfinityBox\MModule\backup_security\id.858F9AD0 .[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V40_F1.BIN_E859B993].rpl
rom info detection finished
TCL-ID detection...
TCL-ID detection done
device-id: 858F9AD0
rom info ver: 05
sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V40_F1.BIN
project-id: MAUI.08A.W08.36.SP1.V40_F1, 93B959E8
code offset: 00000000
ffs offset/size [01]: 00BC0000/00440000
TCL-ID identification
version: 583
provider: 355DX-2BVVBG1
customization: CI58CD11
customization: XI58CD11
TCL-ID identification done
TCL-ID is present
ffs/eeprom address assigned: 00BC0000
startup code area #1 check...
startup code area #1 fixed
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
sim-lock status: disabled
product id: JRD_COMMUNICATION_U91X_PRODUCTS
area1 is invalid
area2 is valid
area3 is valid
area4 is valid
searching sec info#2...
search sec info#2 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
original imei: FFFFFFFFFFFFFF
Backup required data Done
====> Patch required data ...
pass #1
firmware remap[01]: 08000000
pass #2
pass #3
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write: imei
Write: imei
Write: imei
sec info (fast) detection...
security area (sec info, cust) calculation...
identification header detected
error: jump table is not found or incorrect, can't detect customization version
error: can't calculate security area (sec info, cust), existing data will be used
Check support area for updates !
security area (sec info, cust) calculation done
security area (sec info, hash) calculation...
..................security area (sec info, hash) detecting size...
security area (sec info, hash) detecting parameters...
security area (sec info, hash) encoding...
done
Write: security area (sec info, hash)
security area (sec info, hash) calculation done
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: c:\InfinityBox\MModule\backup_security\Alcatel-355DX,355DA_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_ 08A_W08_36_SP1_V40_F1__system_log_858F9AD0_E859B99 3_20120225-112725.B0X.bin
Finished, time used: 4 min 6 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
BesTCooL 02-25-2012 12:49
we wait add 385DX dual sim etc...
YellowBoss 02-25-2012 23:08
Please, try to read full flash from 385D as 355D and send full flash backup to [email protected]
BesTCooL 02-25-2012 23:11
tyred but boot erorr some info Ok after boot error
YellowBoss 02-25-2012 23:14
Please, post here operation log text to check.
BesTCooL 02-25-2012 23:30
oke log save but phone back to customer..
BesTCooL 03-16-2012 15:34
COM11 [Serial2] selected
module v4.20
Action: read flash
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6253:8A04:8A00]...
CPU: MT6253
high speed boot On
chip: 0000:0000:A00F
status: 03
error: bootcode load error: A0
Boot Done
error: no any expected answer : wrong answer after chip cfi request
number of flash chip/regions detected: 00/01
flash chip is unknown or damaged.
Fault reasons:
1. flash chip is damaged: replace or resolder/reball flash chip
2. hardware is damaged: check hardware, water inside etc.
3. unknown hardware: set "Advanced chip detection method" box [un-checked] and try again
4. wrong model selection, try 'NAND' selection
Initialize Fail
Finished, time used: 19 sec
Page generated in 0.20936 seconds with 5 queries
