02-25-2012, 10:43 | #1 (permalink) |
Registered User Join Date: Oct 2005 Location: bulgaria
Member: 189682 Status: Offline Thanks Meter: 48 | alkatel ot-355dx unlock done with infinity MModule 4.12 COM13 [VCP1] selected module v4.12 Device: Alcatel-355DX, 355DA Checking data, wait... advanced flash detection enabled Action: "repair imei" new imei: 350724302577243 ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:B456:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:2BEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: c:\InfinityBox\MModule\backup_security\id.858F9AD0 .[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V40_F1.BIN_E859B993].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 858F9AD0 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V40_F1.BIN project-id: MAUI.08A.W08.36.SP1.V40_F1, 93B959E8 code offset: 00000000 ffs offset/size [01]: 00BC0000/00440000 TCL-ID identification version: 583 provider: 355DX-2BVVBG1 customization: CI58CD11 customization: XI58CD11 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00BC0000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: disabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is invalid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF flash: EC240200000000:2BEA0000000000 Backup required data Done ====> Patch required data ... ................ pass #1 firmware remap[01]: 08000000 pass #2 firmware remap[01]: 08000000 ..... pass #3 firmware remap[01]: 08000000 .......................... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: imei flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: imei flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: imei sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected error: jump table is not found or incorrect, can't detect customization version customization: XI58CD11 error: can't calculate security area (sec info, cust), existing data will be used Check support area for updates ! security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Write Done ====> Finalization ... ffs formatting... flash: EC240200000000:2BEA0000000000 Finalization Done file saved: c:\InfinityBox\MModule\backup_security\Alcatel-355DX,355DA_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_ 08A_W08_36_SP1_V40_F1__system_log_858F9AD0_E859B99 3_20120225-112725.B0X.bin Finished, time used: 4 min 6 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to dbarakov For This Useful Post: |
02-25-2012, 23:08 | #3 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Please, try to read full flash from 385D as 355D and send full flash backup to [email protected] |
03-16-2012, 14:34 | #7 (permalink) | |
No Life Poster Join Date: Dec 2002 Location: TURKEY Age: 44
Member: 18442 Status: Offline Sonork: 111110 Thanks Meter: 622 | Quote:
COM11 [Serial2] selected module v4.20 Device: Alcatel-355DX, 355DA Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6253:8A04:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:A00F status: 03 boot packet size: 0400 error: bootcode load error: A0 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... error: no any expected answer : wrong answer after chip cfi request number of flash chip/regions detected: 00/01 flash chip is unknown or damaged. Fault reasons: 1. flash chip is damaged: replace or resolder/reball flash chip 2. hardware is damaged: check hardware, water inside etc. 3. unknown hardware: set "Advanced chip detection method" box [un-checked] and try again 4. wrong model selection, try 'NAND' selection Initialize Fail Finished, time used: 19 sec Remove/Install battery now ! | |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
