02-14-2016, 09:48 | #1 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | @All Indian users-About Non Supported MTk Nand phones:- Who have MTk Nand phone which is still not supported by CM2MTk-means not reading info with all Nand Init modes and not reading Factory Firmware with Nand Extra mode can contact me via pm, yahoo messenger or on sonork. We will purchase phone or try to support it in coming update. No off-topic post here. Support us to make Infinity CM2 more stronger. Br. Infinity Box Support Team. |
The Following 3 Users Say Thank You to PASSIONATE_BOYS For This Useful Post: |
02-14-2016, 10:12 | #3 (permalink) |
No Life Poster Join Date: Aug 2011 Location: Afghanistan
Member: 1646177 Status: Offline Sonork: 100.1604654 Thanks Meter: 368 | Hope Infinity find a solution for secure boot MTK6571 SP unlock which are not supported http://forum.gsmhosting.com/vbb/f296...rands-2018863/ |
02-14-2016, 10:14 | #4 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,293 | intex aqua 3g intex aqua 3g mini intex y11 alcatel ot-4010d |
The Following User Says Thank You to Deepesh Sharma For This Useful Post: |
02-14-2016, 11:39 | #5 (permalink) | |
Product Supporter Join Date: May 2010 Location: alwar, rajasthan (india)
Member: 1306196 Status: Offline Sonork: 100.1654602 Thanks Meter: 1,567 | Quote:
02-14-2016, 12:51 | #6 (permalink) | ||
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Do you have any of them in hand? Br. Infinity Box Support Team. | ||
02-14-2016, 14:28 | #7 (permalink) | |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,293 | this time have only ot 4010d Quote:
read info Code: Operation : Check / Read Info [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x008D , [TOSHIBA] TYBC0A111557KC [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0000 0000 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/01 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Done! Elapsed: 00:00:08 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x008D , [TOSHIBA] TYBC0A111557KC [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0000 0000 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/01 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Too old device, FW reading not supported! Operation Failed Elapsed: 00:00:28 Reconnect Power/Cable! | |
