04-09-2009, 12:58 | #1 (permalink) |
Junior Member Join Date: Dec 2007 Location: Algeria Age: 34
Member: 666633 Status: Offline Thanks Meter: 3 | To All members Please HELP S.O.S ? How can use the infinity box , i meen for example how to flash n95 chines ? ----------------------- and please tell me , do i have to Welding the cables to the phone sometimes ? and how ? ************ sorry for my english language |
04-09-2009, 19:13 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Hello, How to write flash (upgrade/downgrade firmware, change language): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to read flash: 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "Read flash" (or "Read full flash") button and follow instruction given by software How to unlock (remove sp-lock, provider lock etc.): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (reset setting to default values, repair freez/restart etc.): - at first try to make "safe format" (if this option exist) - if "safe" option is not works try to make "complete" format (if this option exist) 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. select format mode "safe" or "complete" (if mode is available) 9. press "Reset" or "Format" button and follow instruction given by software Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
04-09-2009, 19:20 | #3 (permalink) | |
Freak Poster Join Date: Mar 2007
Member: 476420 Status: Offline Sonork: 100.1605239 Thanks Meter: 164 | Quote:
Hallo to All Member Plz Help Me | R@ZIB-BD | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 12-08-2008 06:37 |
All Member Please Help me for 1112 Dead phone. | .:.GSM-ANGEL.:. | Nokia Digital Core Technology 4 ( DCT-4 ) | 13 | 06-13-2008 17:50 |
to all members plz help!! | mahmoud | Nokia Hardware & Hardware Repair | 4 | 11-28-2002 11:40 |
To All Members - Please Read ! | Bph&co | Off Topic Zone | 81 | 06-03-2002 01:54 |
