Old 03-01-2010, 11:44   #1 (permalink)
THE GREAT ONE's Avatar
Member: 751235
Sonork: 100.1662008
Thanks Meter: 526
to all users .....
E553_K9F8_E553_GPRS_MT6226_S01.00_0.BIN
COM210 [VCP0] selected
module v3.08
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: read/check information
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 0031:E078:F172
status: FF
high speed boot Off
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: EC257E25082501:29EA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
otp offset: 00000000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
interesting cpu type found
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is absent
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.246DD875.[E553_K9F8_E553_GPRS_MT6226_S01.00_0.BIN_10100B95].rpl
rom info detection finished
New firmware detected (v.3.08, database date: unknown):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
device-id: 246DD875
rom info ver: 04
sw version: E553_K9F8_E553_GPRS_MT6226_S01.00_0.BIN
project-id: E553_K9F8.00.0, 950B1010
code offset: 00000000
ffs offset/size [01]: 00800000/001FF000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00800000
checking area [00000000]: 00080000-00FFFFFF...
ffs/eeprom found near: 00E00000
Detected ffs/eeprom address is non-standard: 00E00000
Posible reasons:
1. ffs/eeprom is Ok but address is non-standard
2. ffs/eeprom is damaged and can't be detected
3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make full flash backup for emergency case
3. repeat required operation
Are you sure that detected ffs/eeprom address is correct ?
Do you want to use standard ffs/eeprom address: 00800000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
operation terminated by user
operation aborted
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\_ system_log_246DD875_10100B95_20100301-104327.B0X.bin
Finished, time used: 1 min 11 sec
Remove/Install battery now !
I FORMAT WITH SPIDERMAN AND IS DEAD PLS I NEED FLASH FILE HOPE INFINITY CAN HELP ME
Old 03-01-2010, 13:11   #2 (permalink)
Member: 751235
Sonork: 100.1662008
Thanks Meter: 526
i need flash file to revivr my fone pls help
Old 03-01-2010, 19:16   #3 (permalink)
Member: 751235
Sonork: 100.1662008
Thanks Meter: 526
pls i realy need help here... pls
Old 03-01-2010, 20:10   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
flashfiles/ChineseMiracle/Anycool/Anycool-D66+_E553_K9F8_E553_GPRS_MT6226_S01.00_0_16m_Ru_Fr _Es_En_De_Th_Vn_Cn_Tr_Hi_Cn_Ar.B0M.bin
flashfiles/ChineseMiracle/_MT6205-MT6227/eeprom/E553_K9F8_E553_GPRS_MT6226_S01.00_0__eeprom_01.B0E .bin
Old 03-02-2010, 10:24   #5 (permalink)
Member: 751235
Sonork: 100.1662008
Thanks Meter: 526
thanks fone pwr on fine but still restart with sim... any solution b pls
Old 03-02-2010, 17:35   #6 (permalink)
Member: 148515
hello!
remove sim card and try to call 112.
if phone still restarts- you have damaged Power Amplifier
to all user and team .. attention pls THE GREAT ONE FuriousGold 7 03-30-2010 09:15
warning to all users .. someone is trying to steal accounts strangerboy Board, Server and Login Problems/Support 2 06-19-2008 23:54
Good news to all user and Malaysia user!! alex12345 Main Sales Section 0 01-11-2007 07:48
vygis ready to now to all users egyption fonec VygisToolbox 0 10-22-2004 16:52
to all users about imei siemens komix x1x to x45/x50 1 01-03-2002 12:25
Page generated in 0.22684 seconds with 9 queries
