07-30-2009, 12:56 | #1 (permalink) |
Product Supporter Join Date: Dec 2004 Location: Furious Team ... GPGIndustries Age: 45
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,045 | To All USers About KM335 |
The Following 9 Users Say Thank You to Fast Unlocker For This Useful Post: |
07-31-2009, 10:16 | #2 (permalink) | |
Please, read full flash from KM335 (like KP320) and send full flash backup (or link) to [email protected] Thank you ! | |
07-31-2009, 14:04 | #3 (permalink) | |
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,045 | Quote:
07-31-2009, 16:06 | #5 (permalink) |
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,045 | I will send it to you But Sorry i don,t have ICQ Please let me know if you have messenger or Sonork . |
08-01-2009, 10:48 | #7 (permalink) |
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,045 | Please get your Link From Here |
The Following User Says Thank You to Fast Unlocker For This Useful Post: |
10-15-2009, 09:26 | #15 (permalink) |
Insane Poster Join Date: Sep 2006 Location: philippines
Member: 353512 Status: Offline Thanks Meter: 15 | i gest its not yet supported? even i flash the back up many errors? COM4 [VCP1] selected module v2.91 Action: read codes unlock method: read codes Model: LG-KM335 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6229:8A02:8A02]... CPU: MT6229 chip: 0031:2006:0101 status: FF rom: 4D5710FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6229,E02 Date: 2005.07.11 Version: 1.0 Version: KM335-00-V10a-ARB-XX-MAR-10-2009 Version: 44 byte(s) read imei: 35817902013691 connection Ok 157 byte(s) read 166 byte(s) read Phone lock: Off Network lock: Off Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off Phone code: 0000 Finished, time used: 34 sec Remove/Install battery now ! =================================== COM4 [VCP1] selected module v2.91 Action: read codes unlock method: read codes Model: LG-KP320 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6229:8A02:8A02]... CPU: MT6229 chip: 0031:2006:0101 status: FF rom: 4D5710FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6229,E02 Date: 2005.07.11 Version: 1.0 Version: KM335-00-V10a-ARB-XX-MAR-10-2009 Version: 44 byte(s) read imei: 35817902013691 connection Ok 157 byte(s) read 166 byte(s) read Phone lock: Off Network lock: Off Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off Phone code: 0000 Finished, time used: 20 sec Remove/Install battery now ! ==================================== errors COM4 [VCP1] selected module v2.91 Device: LG-KP320 Checking data, wait... Action: write NAND flash read mode: 01 write: Firmware KP320-00-V10i-404-XX-JUL-01-2008_A7610_07A_PCB03_GPRS_MT6229_S02.7S7610IN00-001-R2R_En_Hi.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs firmware patch sp-lock #0/0 is not required firmware patch sp-lock #1 is not required firmware patch sp-lock #2 is not required source data: page only rom info protocol ver: 04 ver. sw 1: A7610_07A_PCB03_GPRS_MT6229_S02.7S7610IN00-001-R2R.BIN ver. sw 2: 7S7610IN00-001-R2R, 00000000 ffs offset/size: 02000000/06000000 id-page2 area is found, ROM3 extracted nfi area detection finished: Ok Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6229:8A02:8A02]... CPU: MT6229 chip: 0031:2006:0101 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.02 cpu-id: 09 loader: 3.0840.00.00 NAND id: AD79A500 page size: 200+10 pages/block: 20 bits i/o: 08 address cycles: 04 blocks: 2000 external ram: 00000000 finalize connection... done load emi configuration... apply emi configuration... ram size: 02000000 emi configuration done NOR: 0000:000000000000 [00000000] NAND: 00AD:007900A50000 [08400000] NOR chip is not installed Initialize Done Set baud ... 921600 Set baud Done Identification ... ram test... pass 1... pass 2... pass 3... pass 4... done reading bootloader structure area (00010000 bytes)... detecting bootloader structure... source data: page only rom info protocol ver: 04 ver. sw 1: A7321_07A_PCB03_GPRS_MT6229_S02.KM335-00-V10A-ARB-XX-MAR-10-2009.BIN ver. sw 2: KM335-00-V10a-ARB-XX-MAR-10-2009, 00000000 ffs offset/size: 02000000/06000000 nfi area detection finished: Ok detecting bootloader structure by source file... source data: page+spare converting data... done 0x00010000 bytes error: core signature is missing error: unknown or damaged data structure nfi area detection finished: failed warning: can not detect chip parameters, default values assigned startup code area #1 check... startup code area #1 fixed Identification Done Write ... 00006000 bytes sent write core area 1 of 3... 00419000 bytes sent write core area 2 of 3... 00B26000 bytes sent write core area 3 of 3... error: code: A500000BF1 error: code: 5A error: code: A5FD150100 error: code: 000000 error: code: error: block/offset: 00000000/00000000 error: can't write nand core Write Fail Finished, time used: 328 sec Remove/Install battery now ! =================================== error: code: 0000E000E0 error: code: 0000E00000 error: code: E00000E000 error: code: 0000E0E000 error: code: 00E000E000 error: code: 000000E000 error: code: E0E000E000 error: code: 00E0000000 error: code: E000E00000 error: code: 000000E000 error: code: 0000E00000 error: code: E0E0E000E0 error: code: 000000E000 error: code: 00E0E00000 error: code: 00E0000000 error: code: E00000E000 error: code: E000E0E000 error: code: 000000E0E0 error: code: E000000000 error: code: 0000E0E0E0 error: code: 00E000E000 error: code: 00E000E0E0 error: code: E0E0000000 error: code: E0E0000000 error: code: E000000000 error: code: 0000E00000 error: code: E000000000 error: code: E0000000E0 error: code: E00000E0E0 error: code: 0000E00000 error: code: E000E0E000 error: code: E000E000E0 error: code: 000000E000 error: code: E00000E0E0 error: code: 00E00000E0 error: code: E00000E000 error: code: 00E00000E0 error: code: 00E000E000 error: code: 00000000E0 error: code: E0000000E0 error: code: 000000E000 error: code: 00E0000000 error: code: 00E0000000 error: code: 0000000000 error: code: 0000000000 error: code: E0E000E000 error: code: 00000000E0 error: code: E00000E0E0 error: code: 00E0E0E0E0 error: code: E0E0000000 error: code: 00E0000000 error: code: E0E0E000E0 error: code: 00E000E000 error: code: E00000E0E0 error: code: E000E0E000 error: code: E0000000E0 error: code: E000000000 error: code: 00E00000E0 error: code: 00E0E00000 error: code: 00E0E0E000 error: code: 00E0000000 error: code: 000000E0E0 error: code: 0000E00000 error: code: E000E0E0E0 error: code: 00E0E0E0E0 error: code: 0000000000 error: code: E00000E0E0 error: code: E0E000E000 error: code: 00E000E0E0 error: code: E000E000E0 error: code: 00E00000E0 error: code: E0E0E00000 error: code: 000000E0E0 error: code: 0000E00000 error: code: 000000E000 error: code: 00000000E0 error: code: 00E0E000E0 error: code: 0000E00000 error: code: 0000E00000 error: code: E000000000 error: code: 00E00000E0 error: code: E0E0E0E000 error: code: E000E000E0 error: code: 0000000000 error: code: E0E00000E0 error: code: 0000E00000 error: code: 000000E0E0 error: code: 00E000E0E0 error: code: E000E00000 error: code: 0000E0E000 error: code: E0E000E0E0 error: code: E000000000 error: block/offset: 000002E9/002E9000 error: can't write nand core Write Fail Finished, time used: 412 sec Remove/Install battery now ! =============================== rror: code: A500000BF1 error: code: 5A error: code: A5D40100 error: code: error: block/offset: 00000000/00000000 error: can't write nand core Write Fail Finished, time used: 600 sec http://rapidshare.com/files/29287187...091014-17.html |
to all user and team .. attention pls | THE GREAT ONE | FuriousGold | 7 | 03-30-2010 09:15 |
To all users about unlocking and flashing lg ke970 shine in 2.2.9 [THX FOR REPORT] | SUUNNYY | PolarBox 3 | 0 | 10-21-2009 20:59 |
@Admin Please Send Email For all Users about Site Changed | sharaz191 | Forum Announcements | 6 | 02-25-2008 15:17 |
Good news to all user and Malaysia user!! | alex12345 | Main Sales Section | 0 | 01-11-2007 07:48 |
to all users about imei siemens | komix | x1x to x45/x50 | 1 | 01-03-2002 12:25 |
