01-21-2015, 12:56 | #1 (permalink) |
Insane Poster Join Date: Dec 2005 Location: Alien Nation
Member: 210581 Status: Offline Thanks Meter: 25 | always error when backup firmware advance e1c pro Operation : Read Flash [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 42 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 15010034594D443352011337B83A916B DA Stat : v4.2 on BBID : 0x8B DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : R3DMY [eMMC] : FLASH_CID : 15010034594D443352011337B83A916B [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : ADVAN ProdName : Vandroid ProdModel : E1C Pro Device : Vandroid AndroidVer: 4.4.2 MTKxCPU : MT6571 MTKxPRJ : ALPS.KK1.MP7.V1.13 [Read Ok] : preloader_advan12d_7123.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin #4655 : Data CRC Error : 30CD , 731F Error while reading block! Something went wrong Read error Operation Failed Elapsed: 00:01:25 Reconnect Power/Cable! change cable, usb port ,change setting...still error .. |
01-21-2015, 14:23 | #2 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello. It always give exactly same error? Can you try 2 times in a row and post both logs? If they will be same - seems as emmc have bad block in this sector. I can make skip for this, but result can be - bad firmware. And if try read fullflash instead fw - it reads well or not? |
The Following User Says Thank You to Dzirt For This Useful Post: |
01-22-2015, 14:05 | #3 (permalink) | |
Member: 210581 Status: Offline Thanks Meter: 25 | Quote:
