09-15-2017, 13:07 | #12 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Run software as Admin, disable Antivirus or add whole CM2 folder to Tusted/Exclusion list. Make sure no other software is accessing CM2 folder. You can also try to save file in other partition of HDD. If still face problem Uninstall CM2MTK, delete folder and reinstall software once again and repeat process. If nothing helps reinstall windows. Br. Infinity Box Team. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
09-15-2017, 13:16 | #13 (permalink) |
No Life Poster Join Date: Sep 2004 Location: HR Age: 48
Member: 80391 Status: Offline Sonork: 100.1601620 Thanks Meter: 66 | Have the same problem for some time. When the error ocurs, I close CM2MTK and start it again and start reading flash. After that it reads flash OK. That's the pattern, usually it works second time I start it. Asked for help long time ago and the answer was the same. Reinstall Win... Didn't try that cause all other SW on the PC is working just fine. |
