06-25-2008, 08:45 | #1 (permalink) |
Banned Join Date: May 2004 Location: Mauritius
Member: 64823 Status: Offline Thanks Meter: 438 | Always having same problem-> need to unlock PHONE code this is the information: COM13 [VCP0] selected Action: read codes unlock method: read codes Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled Connecting, wait... error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 98 sec Remove/Install battery now Even i press POWER BUTTON for long time !! |
06-25-2008, 09:55 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | please, next time make your post in correct forum section: http:///vbb/forumdisplay.php?f=425 1. be sure that you have pressed phone "Power" button long enough 2. you can try to make "format" in "complete" mode, then restore original imei. Phone code should be resetted to default value, f.e. 1122 Do not forget to make full flash backup before any operation ! |
06-25-2008, 18:27 | #3 (permalink) | |
Member: 64823 Status: Offline Thanks Meter: 438 | Quote:
it WORKSSSSSS | |
Read MCU and DSP Timestamps problem -> Failed to obtain Phone Unique Data | DaWizard | Cyclonebox | 16 | 02-21-2010 06:56 |
panasonic g50 code needed to unlock phone | ~stuie~ | Phone Unlocking Codes & Maps | 6 | 07-11-2004 14:09 |
ST55 phone code LOCKED- how to unlock phone code ? | PSG | E-Gold Based Phones | 4 | 11-20-2003 15:33 |
NEED HELP TO UNLOCK PHONE CODE ON c26 v61 | vladwork1974 | x1x to x45/x50 | 6 | 11-24-2001 10:48 |
NEED HELP TO UNLOCK PHONE CODE ON SL 45 | .:SkiR:. | x1x to x45/x50 | 1 | 11-15-2001 05:54 |
