05-14-2015, 14:40 | #1 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Chinese Miracle-2 MTK/MediaTek v1.21 - many improvements MediaTek SP Platform - Flash Engine updated MT6592 Flashing supported! MT6575/MT6577 Flashing improved Big ROM flashing improved Some improvements and bugfixes Supported CPU for Flash Writing: MT6575, MT6577 eMMC only MT6571, MT6572, MT6582, MT6589, MT6592, MT83xx eMMC only MT6732, MT6752, MT6753, MT8752 eMMC only MT8127 eMMC only - Factory FW reading improved MT6592 Factory FW reading improved Some HTC phones support improved (HTC 320, HTC 626, HTC 526) - Service Operations improved "InitPreloader" supported for MT6592 "Fix Unknown BaseBand" supported for MT6592 "DLFix" (DL Image Tool Fail error repair) supported for MT6592 "Flash Erase" supported for MT6592 NVRAM operations supported for MT6592 "Format FS" (UDA + CACHE) supported for MT6592 "Write Flash" (DUMP) supported for MT6592 Alcatel "ProInfo Tool" activated for MT6592 - Unlock Operations improved "Direct Unlock" operation supported for MT6592 New models supported HTC 526G (MT6592) HTC 626G (MT6752) HTC 320 (MT6582) - UserData Operations improved Privacy (AntiTheft) Lock reset supported for MT6592 Privacy (AntiTheft) Lock reset without UserData loose supported for MT6592 - Other Android 5.x OS support for: PatternLock Read, Safe PrivacyLock reset, Full Identify Most fixes for 5.x is for speed-up operations No USB Debug, Root required DRAM Init improved: MT6592, MT6572, MT6732 supported CompileInfo extraction for DUMP Read/Write was broken, fixed Some Bugfixes and improvements at all Download: Infinity-Box - Support http://forum.gsmhosting.com/vbb/f296...llers-1943689/ Infinity-Box 10 (ten) years (2005 - 2015) non-stop regular updates and support as nobody else: Infinity-Box - News New features, Unlock Codes (Huawei, Motorola, Samsung etc.), iPhone Unlock, Software Activations released for Infinity-Box Online Service - World biggest flash files database for several thousands brands/models - BB5 Easy Service Tool [BEST] Dongle - CDMA-Tool Dongle (fast and easy unlock) - Infinity-Box Dongle ready for delivery - Follow us on Twitter |
The Following 14 Users Say Thank You to YellowBoss For This Useful Post: |
05-14-2015, 15:38 | #3 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Dera Ismail Khan (KPK) Pak
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | nokia mtk like (108...225..220..130) contact servace imei repair ??????????/ |
The Following User Says Thank You to rahihimkhan For This Useful Post: |
05-14-2015, 15:56 | #5 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | QMOBILE X11 pattern lock read Code: Operation : Read PatternLock [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040503A210C1C16D DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164040503A210C1C16D [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... FS Size : 2400 MiB Magic Ok Mount point : /data Get PatternLock ... PatternLock Sequnce : 4258 Done! Elapsed: 00:00:23 |
05-15-2015, 06:59 | #12 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Kazakhstan
Member: 19032 Status: Offline Thanks Meter: 158 | Lenovo Tab 2 A30-HC, not repair IMEI Code: Operation : Repair Security [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Device boot not done Check Drivers Try again Init Service mode failed, something went wrong :( Reconnect Power/Cable! |
05-15-2015, 13:25 | #14 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Intex Aqua Y2 Pro- read FF, NVRAM and Pattern Lock done- Read factory Firmware- Code: Operation : Read Flash [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 60 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D4330344758EA1ADDF3B19F DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : G40CM [eMMC] : FLASH_CID : 7001004D4D4330344758EA1ADDF3B19F [eMMC] : FLASH_LEN : 0x00000000E6800000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : Intex ProdName : Aqua_Y2_Pro ProdModel : Aqua Y2 Pro Device : Aqua_Y2_Pro AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : Intex_Aqua_Y2_Pro_V08_Indian [Read Ok] : preloader_wt97057.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6572 / V1.1.1 / wt97057 / EMMC FW Size : 705 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6572__Intex__Aqua Y2 Pro__Aqua_Y2_Pro__4.4.2__Intex_Aqua_Y2_Pro_V08_Indian\ All done! Done! Elapsed: 00:03:57 Reconnect Power/Cable! Code: Operation : Read NVRAM [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 60 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D4330344758EA1ADDF3B19F DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : G40CM [eMMC] : FLASH_CID : 7001004D4D4330344758EA1ADDF3B19F [eMMC] : FLASH_LEN : 0x00000000E6800000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Read Ok, Intex Cloud Y2-Pro_MT6572_eMMC.spnv saved Done! Elapsed: 00:00:40 Reconnect Power/Cable! Code: Operation : Read PatternLock [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 60 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D4330344758EA1ADDF3B19F DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : G40CM [eMMC] : FLASH_CID : 7001004D4D4330344758EA1ADDF3B19F [eMMC] : FLASH_LEN : 0x00000000E6800000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... FS Size : 1323 MiB Magic Ok Mount point : /data Get PatternLock ... PatternLock Sequnce : 6589 Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
