10-20-2015, 21:34 | #1 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Ambrane A-707 Rockchip RK3026 Can't Take Driver. It's Ambrane A-707 3G Through Dongle Tablet. Problem : Blinking With "Ambrane" Logo. Even Hard Reset Done. I Have This Firmware : E2215_M760E3_RK3026-v1.5_ambrane-LOGO_APK_20140118.img First I Tried With This Drivers C:\InfinityBox\CM2RKT\Drivers\x86\xp But It Didn't Work So I Tried With This : RockusbDriver_3066, But Both Drivers Not Work. Here Is Reference Thread But Not Exactly Same. |
10-21-2015, 06:46 | #2 (permalink) |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,215 | Search Driver Via Driveridentifier |
10-21-2015, 17:27 | #4 (permalink) |
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | My Dear Best Friend, It's Show "USB Device" With Yellow Color In Other Devices Section. Details Of USB Device Properties : USB\VID_2207&PID_292C\5&94B8C27&0&2. Should I Upload Picture Of ScreenShoot If Possible ?. Last edited by MyGSM World; 10-21-2015 at 17:34. |
10-21-2015, 17:55 | #5 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Ok, try updated drivers : DriversRKT_v1.01 - Download - 4shared |
10-21-2015, 18:28 | #6 (permalink) | |
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Quote:
Driver Working Very Well, Like Unbelievable. Can't Understand, What "Magic" Are You Using ?. Chinese Miracle II [RKT Module] v 1.0 Code: Connect device to PC! Hold 'VolUp'+'VolDown' or 'VolUp', insert USB cable, press 'PowerOn'! Found active FlashInterface , connecting ... Detected : RK3066 Read Info Ok! Operation : ReadInfo [ v1.0 ] ======= Flash Info : Channel : 0x00 FlashType : 2C44444BA9 FlashSize : 0x000000010A000000 FlashCaps : 2097152/8192/32/40/4 ======= Device Info : Read Info Ok! Elapsed: 00:00:00 | |
10-21-2015, 19:02 | #7 (permalink) |
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | My Dear Best Friend, I'm Facing This Error While "Read Firmware". Chinese Miracle II [RKT Module] v 1.0 Code: Connect device to PC! Hold 'VolUp'+'VolDown' or 'VolUp', insert USB cable, press 'PowerOn'! Found active FlashInterface , connecting ... Detected : RK3066 Read Info Ok! Code: Collect InitData ... Reading now ... Reading : PARAMS Reading : MISC Reading : KERNEL Reading failed! Send report to support with all logs! Elapsed: 00:00:16 |
10-27-2015, 18:55 | #9 (permalink) | |
Operation : Read Flash [ v1.0 ] Code: Collect InitData ... Reading now ... Reading : PARAMS Reading : MISC Reading : KERNEL Reading : BOOT Reading : RECOVERY Reading : BACKUP Reading : CACHE Reading : USERDATA Reading : SYSTEM Read Ok! Firmware size : 741 MiB Saved as : RK3066__A707.irkfw Done! Elapsed: 00:05:08 So I Decided To Write Factory Firmware But Firmware Can't Show In "Firmware [ IRFW / UIMG ]". So I Tried To Change File Type .img To .irkfw. Then It's Show "BAD file selected! Select correct RK IFW!" E2215_M760E3_RK3026-v1.5_ambrane-LOGO_APK_20140118.img E2215_M760E3_RK3026-v1.5_ambrane-LOGO_APK_20140118.irkfw Simple Question : How To Write Factory Firmware By CM2 ?. | |
The Following User Says Thank You to MyGSM World For This Useful Post: |
10-28-2015, 14:12 | #11 (permalink) |
Freak Poster Join Date: Nov 2011 Location: rwp
Member: 1686412 Status: Offline Sonork: 100.1664625 Thanks Meter: 212 | Connect device to PC! Hold 'VolUp'+'VolDown' or 'VolUp', insert USB cable, press 'PowerOn'! Found active FlashInterface , connecting ... Detected : RK3066 Read Info Ok! Operation : Read PatternLock [ v1.0 ] Reading PatternLock ... Decrypt PatternLock Sequence : 3698521 Elapsed: 00:00:01 Connect device to PC! Hold 'VolUp'+'VolDown' or 'VolUp', insert USB cable, press 'PowerOn'! |
