Old 02-14-2020, 16:33   #1 (permalink)
Member: 2108610
Thanks Meter: 379
Amgoo AM402 SPD SC7720EA not supported by infinity, any solution?
Amgoo AM402 SPD SC7720 not supported by infinity, infinity not have loaders for SC7720EA any solution?
Old 02-15-2020, 05:22   #2 (permalink)
Member: 1677653
Thanks Meter: 2,769
Where is your operation log?
Old 02-15-2020, 07:08   #3 (permalink)
Member: 2108610
Thanks Meter: 379
For What Logs if Infinity not have this loaders bro??
Try with diferents loaders
Here with SP2
Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.03
Load IDBase v10107 Ok!
Operation : Identify [ v2.03 ]
BootMode : FLASH
1. Power off device, wait 10-15 seconds
2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- )
3. Insert cable in device!
Wait for device ...
Device Connected!
ERROR : Protocol HandShake failed!
Error : Fail to init protocol!
Remove battery, cable. Check cable and connection. Repeat operation!
Reconnect Power/Cable!
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS
Sending Init Boot ...
Boot sent!
Kick FDL ...
ERROR : FDL NOT started!
Error : Fail to boot FDL!
Unsupported device with selected fdl! Change settings!
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC7731x_BASE : SC7731GEA_eMMC_1GB_NS
Boot sent!
Kick FDL ...
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_512MB_SS
Boot sent!
Kick FDL ...
BootMode : FLASH
Wait for device ...
Device not found!
Card found : 997D19B7 , v0138
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_512MB_RS
Boot sent!
Kick FDL ...
Here with InfinitySPD
Chinese Miracle II [SPD module] v 1.27
Set mode to : SP [SC773x] eMMC [Android 6.x]
========================= Start =========================
11/02/2020 / 15:03:26
Card found: S/N : 997D19B7 , v0138
Set mode to : SP [SC773x] eMMC [Android 5.x]
Set mode to : SP [SC773x] eMMC [Generic 4.x-5.0]
Set mode to : SPD6530_SAMSUNG
Set mode to : [AltLDR] SP [SC773x] eMMC [Android 6.x]
14/02/2020 / 9:55:27
Set mode to : SP SC77xx [Model Select]
Start at : [14/02/2020 / 9:56:17]
Operation : Check/Read Info [ v1.27 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
==== Wait for phone...
Phone found! [ 87 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
Boot failed!
DS : Loader start failed! Wrong Model selection!
Boot failed!
Finish at : [14/02/2020 / 9:56:45]
14/02/2020 / 10:55:50
Set mode to : SP [SC8830] eMMC [Generic]
Start at : [14/02/2020 / 10:57:32]
3. Insert cable
Phone found! [ 87 ]
Open Port Failed!
Finish at : [14/02/2020 / 10:57:36]
Start at : [14/02/2020 / 10:57:46]
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
3. Insert cable
Phone found! [ 87 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [14/02/2020 / 10:59:34]
Old 02-15-2020, 08:11   #4 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Make identify first in diag mode.
The Following User Says Thank You to JayDi For This Useful Post:
Page generated in 0.13890 seconds with 8 queries
