01-27-2009, 00:14 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Algeria
Member: 56090 Status: Offline Thanks Meter: 162 | Amoi A203 wht's the next step? with Pinfinder i have found Rx & Tx here below the log : software version: 1.16 cable type: 1x10 (L10A) platform: PMB: Infineon s-gold searching adapter at COM3... adapter found, version: 2000 pins: 10, plain power cycles: 1 activation cycles: 1 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... s-gold2 (C0) result: Rx:9 Tx:1 time required: 24 sec Power On ! -------------- Now the next step ? what model should i choose to read flash or unlock (perhaps) Between i have successfully repaired one alcatel C701x and also flashed kg298(china lng) with kg290 to change language operation ok, thanks infity team Salam |
01-27-2009, 01:39 | #2 (permalink) |
Member: 56090 Status: Offline Thanks Meter: 162 | Sorry i have made a mistache is cable type: 1x5 (L5A) like motorola usb connector and i can't find pinout But when i plug motorola usb cable a window appear with message locosto to install driver Salam Last edited by abdoune; 01-27-2009 at 01:47. |
Fat Blaster The Next Step (??????) (box packing VCD) (USA) (Region ALL) (47 min.) | IPMART | ipmart WebShop | 0 | 12-18-2009 10:20 |
what is the next step | irfan_gsm | Infinity-Box | 20 | 12-04-2009 14:39 |
amoi a203 possible? here the chip.... | SLIPLOCK | Infinity-Box | 9 | 11-10-2008 00:16 |
need help AMOI A203 | SLIPLOCK | Various | 0 | 06-11-2008 04:36 |
amoi a203 | hitechpro | FuriousGold | 0 | 05-19-2008 15:23 |
