10-21-2014, 14:55 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: hall road pakistan
Member: 782530 Status: Offline Thanks Meter: 8,136 | Amzing Problem Mt6572 Nand I read Flash file on working phone Here is logs. 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 30 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00C800F4000000000000000000000000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0090 , [Gigadevice] GD5F4GQ4UAYIG [NAND] : FLASH_DIE : 00C8 00F4 0000 0000 0000 0001 0BC3 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Read Ok , collect info MTKxCPU : MT6572 MTKxPRJ : s3520ap Saved to : C:\InfinityBox\CM2MTK\Flash\MT6572__s3520ap.ispff Done! Elapsed: 00:04:59 Reconnect Power/Cable! FlashFile Size 492 Mb But When I upload flash for I face this error Card found: S/N .................. Chinese Miracle II [MTK module] v 1.04 Load File Bad file detected! Load File Bad file detected! Load File Bad file detected! Where is Problem ????? |
10-21-2014, 15:17 | #2 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello , there is no problem. When I finish NAND flashing - it will be enabled. Files Ok and working , it shows bad - because flashing for nand not activated. |
The Following User Says Thank You to Dzirt For This Useful Post: |
10-21-2014, 19:05 | #6 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | 98% of other "teams" uses CommZero platform, which updated for years. They still fix and improve something , so , I not care about that. Just take a look what we done for half of year : RDA full support, safe SPD and full repair, much things on MTK and rest. And it just a start. Other will made that for next few years, probably |
The Following 5 Users Say Thank You to Dzirt For This Useful Post: |
