-   Infinity-Box (http://forum.gsmhosting.com/vbb/f296/)
-   -   another pcb pinout n95 8gb dual sim, help (http://forum.gsmhosting.com/vbb/f296/another-pcb-pinout-n95-8gb-dual-sim-help-863308/)
ru_dee 11-19-2009 02:52
hello :)
Phone is alive and is sp-locked.
but find problem finding it rx/tx
cpu is mt6225
charge connector: mini usb 5pin
here's pic
[IMG]http://3.bp.********.com/_J-_GDh37_lc/SwPtVVzA4DI/AAAAAAAAAFU/k4GJrMxGVa4/s400/DSC01006.JPG[/IMG]
[IMG]http://1.bp.********.com/_J-_GDh37_lc/SwPtVnY9p-I/AAAAAAAAAFc/wPs2M0MGDb8/s1600/DSC01004.JPG[/IMG]
i had tried to use CM cable 5A, but failed detecting pins..
tried to use pin out from hf port, still no luck..
i also searched in this folder
c:\program files\infinity box\chinese miracle\pinout\
i couldn't find one matching this phone's pcb layout.
been searching forum, still didn't find one
then i tried this way:
http://forum.gsmhosting.com/vbb/show...pinout+n95+8gb
hello!
please take a look how easy is examinate your phone for correct pinout.
as you can see- battery is attached (phone powered On or not- does not metter). One multimeter probe is on GND (metall shield)
with another you touch one by one all points.
when you see 2,7-2,9 volts- this is Tx/Rx
On my example i am touching correct data pin (voltage 2,7 volts)
i found 3 places w/ output 2.74v
here's pic
[IMG]http://1.bp.********.com/_J-_GDh37_lc/SwPtVBcjiZI/AAAAAAAAAFM/DJ5Brsp2enc/s400/DSC01010edit.JPG[/IMG]
then i tried to combine it
1&2
1&3
2&3
as rx/tx, but pin finder still can't find it
help :)
ru_dee 11-19-2009 03:59
i forgot to mention, i use ground also when searching, on gold line area left side pcb :)
InfinityHelp 11-21-2009 16:15
hello!
try 1 and 2 again.
first time try 1 as tx, 2as rx
next time try 1 as rx, 2 as tx
both times your box ground pin 8 must be connected with grounded phone part
Page generated in 0.14379 seconds with 5 queries
