06-23-2008, 13:34 | #1 (permalink) |
No Life Poster Join Date: Dec 2002 Location: TURKEY Age: 44
Member: 18442 Status: Offline Sonork: 111110 Thanks Meter: 622 | anoyone have this flash Trident MB-700 |
10-23-2008, 07:19 | #5 (permalink) |
No Life Poster Join Date: Apr 2000 Location: Bulgaria Kyustendil Age: 47
Member: 1191 Status: Offline Thanks Meter: 128 | pinout is 1x18 pins i found rx and tx near CPUs. but can't read it: this is ot MT6205: COM12 [VCP0] selected module v2.65 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled Connecting, wait... only this. for other CPU MT6226 can't read it. this is pictures on mobile: |
10-23-2008, 07:27 | #6 (permalink) |
Member: 1191 Status: Offline Thanks Meter: 128 | this is wher try Format FFS: safe mode COM12 [VCP0] selected module v2.65 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled Connecting, wait... error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 100 sec Remove/Install battery now ! this is from "Read detailed information": COM12 [VCP0] selected module v2.65 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read/check detailed information Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: SUNHIGH05_06A_PCB02_GSM_MT6205B_DN.X6_06_44_8312_V 1_23-TN-MP-4B-QN.BIN ver. sw2: X6.06.44.8312.V1.23-TN-MP-4B-QN, 00000000 ffs offset/size: 00700000/00100000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00700000 flash: 01227E22022201:18E59F00000000 checking area[00000000]: 00000000-007FFFFF... eeprom/ffs found near: 00700000 detecting eeprom/ffs size... eeprom/ffs size: 00100000 ffs chip: 00 eeprom/ffs area: 00000000:00700000-007FFFFF detecting ffs structure pass 1... ....... detect standard fat location pass #1... ............ detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #1 detected ok detecting ffs structure pass 2... .......... detect standard fat location pass #1... ............ detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #2 detected ok Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... Finished, time used: 32 sec Remove/Install battery now ! |
10-23-2008, 07:40 | #7 (permalink) |
Member: 1191 Status: Offline Thanks Meter: 128 | ok, on MT6205 i make Format FFS Complete but if phone is with SIM card after start and 5-10sec. turn OFF. i can't make Format FFS Safe mode. write IMEI only with mode-3. with mode-1 and mode-2 can't write IMEI. how to fix this mobile ? how to make Format FFS on MT6226 ? (i have it's rx and tx) |
10-23-2008, 22:10 | #9 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! thank you for sharing pinout!!! I am glad that you solved this problem |
Trident MB-700 flash please | demo_55 | Infinity-Box | 1 | 10-28-2008 21:40 |
Someone have this flash for A100. | Pandemonio100 | Panasonic | 0 | 11-20-2004 13:43 |
Who have this flash and SW for it... | Genius | Panasonic | 3 | 12-24-2002 20:05 |
