09-12-2007, 19:21 | #1 (permalink) |
Freak Poster Join Date: Aug 2003 Location: Madrid,Spain Age: 48
Member: 37840 Status: Offline Thanks Meter: 19 | I-mobile 901 dead afer flash !! .................................................. ................. COM13 ready Loading file v.02... IMobile-901_MADDRTATH0TP7B50D_MADRID_HW_B4_Jun-30-2006_901P64-66-V10z-XXX-XX_En_Th[1].B0M.bin loaded COM13 [VCP0] selected Device: I-Mobile 901 Checking data, wait... advanced flash detection active Action: write flash "smart write" active write: Firmware skip: Customization skip: Language Pack skip: Eeprom Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6217:8A00]... boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 98004900000001:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Check space... reading [eeprom]... file saved: backup_eeprom_20070911-201341.B0E.bin Check space Done Manipulation... Manipulation Done Finalization... Finalization Done Write... Area: Firmware flash: 98004900000001:29EA0000000000 Write: Firmware Write Done Finished, time used: 381 sec Remove/Install battery now ! .................................. I have other phone ,same model,working fone,I try read full flash ,finished OK but I try flash dead phone, load firmaware but infinitibox said "data error " and can't flash dead phone.... Please i need a good flash ....or solucion.. Best Regards |
09-14-2007, 04:56 | #4 (permalink) |
No Life Poster Join Date: Oct 2003 Age: 43
Member: 40602 Status: Offline Thanks Meter: 118 | same here, too bad i forget to backup first, now the set only white screen, ful flash with the file in the support but still problem exist, no eeprom repair for this model yet. br, s1emens |
09-14-2007, 07:17 | #5 (permalink) |
Freak Poster Join Date: Nov 2004 Age: 49
Member: 90058 Status: Offline Thanks Meter: 97 | i-mobile 313 the logCOM3 selected Device: IMobile-313 Checking data, wait... Action: read flash Boot... Press Power button now ! Checking... boot answer: 01 Boot Done Set Baud... Set Baud Done Connecting... flash: 80FA:8000 Connecting Done Check free space... flash chip supported Check free space Done Check parameters... Check parameters Done backup critical area... Reading [eeprom-sta]... loading data... error: source buffer too small: 00000000 instead of 0000000A backup critical area Done Check memory... Reading [flash]... Completed Finished, Remove/Install battery now ! Time used: 54 sec please help me brand new |
09-14-2007, 17:06 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Regarding I-Mobile 901: As I can understand phone can power-on aftyer flashing and can work but LCD show nothing. Right ? If so, this means that need to use other firmware for this phone, firmware that support LCD type that installed in your phone. What to do: find phone with similar hardware, read flash and send to [email protected] (if you have original flash backup send it too). We will check your file and prepare good file, ready for flashing in your phone for repair. |
09-14-2007, 19:16 | #7 (permalink) |
Member: 40602 Status: Offline Thanks Meter: 118 | As for me, 1st of all the phone always saying memory full, and after i format ffs with infinity the phone becomes white screen only. Full flashing also not working. Let me see if i can find a healthy 901 i-mobile, read flash and send it you, but it could take a while since this phone is a rare one in my place. Now the cust ask me to return the phone into previous condition, which i can't. Any help will be highly appreciated :P br, s1emens |
09-24-2007, 05:15 | #9 (permalink) | |
Member: 40602 Status: Offline Thanks Meter: 118 | Quote:
br, s1emens | |
09-27-2007, 19:24 | #11 (permalink) |
Member: 40602 Status: Offline Thanks Meter: 118 | here is my log after tried with safe format: COM3 [VCP0] selected Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6217:8A00]... Connecting, wait... error: can't finalize test moide Operation failed ! Finished, time used: 23 sec Remove/Install battery now ! can't be done, i'm sending you a backup full flash and eeprom, readed in a healthy 901 in [email protected] right now, hope to have your reply soon. Thanks br, s1emens |
09-27-2007, 19:35 | #12 (permalink) |
Member: 40602 Status: Offline Thanks Meter: 118 | MY ***!!!!! Finally, after write the backup eeprom from the phone above it revived, but its default is tagalog :P guess have to change it to english. Ignore the full flash sent by me and just analyze the eeprom backup in my email. So happy dont have to buy the customer a 901. Thanks a lot infinity team for this great box. br, s1emens |
09-28-2007, 00:38 | #13 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, uploading in support area now: IMobile-901_MADDRTATH0TP7B50D_MADRID_HW_B4_Jun-28-2006_901P64-66-V10z-XXX-XX-JUN-27-2006_En_Th Codes: http://www.atm-box.com/index.php?id=utilities set default language: *#0000# Send set English language: *#0044# Send |
09-28-2007, 04:28 | #14 (permalink) |
Crazy Poster Join Date: Oct 2006 Location: indonesia
Member: 381947 Status: Offline Thanks Meter: 52 | i have problem, flash ok but hp dead and make "safe format" this : COM3 [VCP0] selected Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6217:8A00]... Connecting, wait... error: can't finalize test moide Operation failed ! Finished, time used: 22 sec Remove/Install battery now ! why error: can't finalize test moide Operation failed ! |
09-28-2007, 09:21 | #15 (permalink) | |
Probably this error take place due to serious damaged eeprom. Make "Complete" format. | |
i-mobile ceo889 dead after flash | eko_java_cell | Infinity-Box | 9 | 10-21-2008 20:55 |
i mobile 901 dead | ruvanw1979 | Infinity-Box | 5 | 06-30-2008 16:43 |
k800i dead afer flash | Shady_Slim | Universalbox | 11 | 11-25-2006 22:34 |
V3 dead afer flash | ChinaMobile | Smart-Clip | 11 | 11-09-2006 10:09 |
a55 dead afer flash | assel | E-Gold Based Phones | 1 | 01-11-2004 17:50 |
