10-26-2008, 02:39 | #1 (permalink) |
Freak Poster Join Date: Oct 2006 Location: team pilipinas
Member: 376326 Status: Offline Thanks Meter: 32 | 6120c dead can i revive this w/ infinity? infinity team can you help me to revive my phone heres my logs COM5 [VCP0] selected module v2.65 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:FB03:0003 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.B9EF6F90.[MT6225_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_08_M P_V27.BIN_048CDB12].rpl identification#1 detection finished device-id: B9EF6F90 identification#1 protocol ver: 04 ver. sw1: MT6225_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_08_M P_V27.BIN ver. sw2: MAUI.06B.W07.08.MP.V27, ED2473FB ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: EC257E25082501:18E59F00000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: EC257E25082501:18E59F00000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_B9EF6F90_MT6225_06B_PCB01_GPRS_MT6225_S0 0.MAUI_06B_W07_08_MP_V27.BIN_048CDB12_20081026-093853.B0X.bin Finished, time used: 43 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
10-26-2008, 04:40 | #2 (permalink) |
Registered User Join Date: Mar 2007 Location: Bandung, Indonesia
Member: 461468 Status: Offline Thanks Meter: 139 | Sirs, please used power supply not battery before due I ever the same problem like u. After power is on normally n then use battery back. Rgds, |
10-26-2008, 14:35 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If phone can ot On after format it may be that you need to flash phone with firmware file. Also in many cases it\'s need to check phone hardware, f.e. rehot/reball flash and CPU chip. |
dead cect u90 revived with infinity | aliakbar | Infinity-Box | 8 | 06-01-2009 16:23 |
R300 dead after unlock revive by infinity | ayhen42 | Infinity-Box | 4 | 05-18-2009 21:44 |
How can I revive this SE K600 ? Not power On. | Grupo MovilFree | SETool2 | 4 | 03-23-2009 19:37 |
X701 restarts itself,Can i fix this by infinity? | Mr GsM | Infinity-Box | 3 | 06-29-2008 14:25 |
