09-08-2017, 14:27 | #1 (permalink) |
Registered User Join Date: Oct 2012
Member: 1822958 Status: Offline Thanks Meter: 45 | Is any firmware compatible Using LGS loading either KDZ, DZ or TOT: Firmware damaged or in unknown format! Send report to support! CM2QLM with .xml qfil style files: Firmware damaged or in unknown format! Send report to support! MTK using scatter files: you guessed it, Firmware damaged or in unknown format! Send report to support! now the apps are looking for scatter/kdz/xml files and such so we can rule out unknown format problem, but all these files have successfully flashed before and after trying them on infinity stuff so i know the files arent damaged in any way, how can i make them flash with infinity? |
09-09-2017, 02:25 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. It support modern generic file formats. In lgs there is some old formats from android 3-4 not supported, because they very old. In mtk - probably you trying load nand scat? They will be supported in v2. In qlm - probably you try load legacy xml bundle? Legacy models ( non fh ) will be supported in another our module. Anyway - make logs + file names , which you try load. That helps alot to determine problems and fix them. |
