05-02-2011, 15:54 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: ---- Age: 35
Member: 959010 Status: Offline Sonork: 100.1602440 Thanks Meter: 445 | Need some help from infinty M705DHZ_PCB01_GPRS_MT6223_S00.KAAM705DHZ_2_03_616_ _fullflash_20110501-141905.B0M COM6 [Serial2] selected module v3.30 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware M705DHZ_PCB01_GPRS_MT6223_S00.KAAM705DHZ_2_03_616_ _fullflash_20110501-141905.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:52A9:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 230400 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is absent startup code area #1 record #1 is damaged, recalculation required rom info detection finished device-id: B278F5DE rom info ver: 05 sw version: M705DHZ_PCB01_GPRS_MT6223_S00.KAAM705DHZ_2_03_616. BIN project-id: KAAM705DHZ_2.03.616, 32E24251 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [protected] type (05), 1 record(s) TCL-ID is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... rpl file not found: C:\InfinityBox\ChineseMiracle\id.B278F5DE.[M705DHZ_PCB01_GPRS_MT6223_S00.KAAM705DHZ_2_03_616. BIN_5142E232].rpl rpl file not found: C:\InfinityBox\ChineseMiracle\id.B278F5DE._M705DHZ _PCB01_GPRS_MT6223_S00.KAAM705DHZ_2_03_616.BIN_514 2E232_.rpl rpl file not found: C:\InfinityBox\ChineseMiracle\backup_security\id.B 278F5DE.[M705DHZ_PCB01_GPRS_MT6223_S00.KAAM705DHZ_2_03_616. BIN_5142E232].rpl rpl file not found: C:\InfinityBox\ChineseMiracle\backup_security\id.B 278F5DE._M705DHZ_PCB01_GPRS_MT6223_S00.KAAM705DHZ_ 2_03_616.BIN_5142E232_.rpl ==================== warning: unknown firmware: M705DHZ_PCB01_GPRS_MT6223_S00.KAAM705DHZ_2_03_616. BIN_5142E232 Unknown firmware found (v.3.30, database date: 01.05.2011), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: M705DHZ_PCB01_GPRS_MT6223_S00.KAAM705DHZ_2_03_616. BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed detecting startup code area #2... startup code area #2 is absent You can flash phone now but can not finalize it, in most cases phone CAN NOT power-on. Do you want to continue anyway ? Area: Firmware flash: 2088C4FFFFFFFF:2088C400000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 1 min 19 sec Remove/Install battery now ! |
05-03-2011, 05:33 | #3 (permalink) |
Member: 959010 Status: Offline Sonork: 100.1602440 Thanks Meter: 445 | Thank you brother! problem solved COM6 [Serial2] selected module v3.30 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware M705DHZ_PCB01_GPRS_MT6223_S00.KAAM705DHZ_2_03_616_ 2009-06-16_16m_En_Fr_Id_Ar.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:52A9:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 230400 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is absent startup code area #1 record #1 is damaged, recalculation required rom info detection finished device-id: B278F5DE rom info ver: 05 sw version: M705DHZ_PCB01_GPRS_MT6223_S00.KAAM705DHZ_2_03_616. BIN project-id: KAAM705DHZ_2.03.616, 32E24251 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [protected] type (05), 1 record(s) TCL-ID is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... normalized firmware detected: M705DHZ_PCB01_GPRS_MT6223_S00.KAAM705DHZ_2_03_616. BIN ==================== New firmware found (v.3.30, database date: 01.05.2011): M705DHZ_PCB01_GPRS_MT6223_S00.KAAM705DHZ_2_03_616. BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== startup code area #1 calculation... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: 2088C4FFFFFFFF:2088C400000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 1 min 1 sec Remove/Install battery now ! |
05-03-2011, 06:01 | #4 (permalink) | |
No Life Poster Join Date: Nov 2008 Location: GSM WORLD
Member: 898387 Status: Offline Sonork: 1000.2 Thanks Meter: 103 | Quote: | |
The Following User Says Thank You to OTIENOJULIUS For This Useful Post: |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
