03-18-2010, 12:42 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: COME & MADE GREEN WORLD
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | new phone USHA LEXUS 303B READED OK ON INFINIITY. Code: COM46 [VCP0] selected module v3.10 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6205:8B00]... CPU: MT6205 high speed boot On boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 detecting chip #01 in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 detecting chip #02 in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 detecting chip #03 in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 detecting chip #04 in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 detecting chip #05 in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 detecting chip #06 in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 detecting chip #07 in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 detecting chip #08 in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 detecting chip #09 in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 detecting chip #0A in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 detecting chip #0B in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 detecting chip #0C in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 detecting chip #0D in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 detecting chip #0E in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 detecting chip #0F in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 10/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 detecting chip #01 in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00400000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00380000 standard ffs/eeprom offset confirmed: 00380000 detecting ffs/eeprom size... ffs/eeprom size: 00080000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00380000-003FFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: _fullflash... file saved: C:\Program Files\InfinityBox\ChineseMiracle\_fullflash_20100318-170257.B0M usha lexus 303b Finished, time used: 3 min 26 sec Remove/Install battery now ! |
The Following User Says Thank You to debmobile For This Useful Post: |
03-19-2010, 04:53 | #3 (permalink) |
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | hi i have no image for this phone, but i edit this pinout 100% work. plese add this. thanks |
03-20-2010, 16:29 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Thank you, we will add this picture in next "Pinouts" update. Also, if somebody will be able to find exact Rx/Tx pins, please, send an information to [email protected] |
Infinity-Box: non-stop updates: Coral-450, HT-Mobile-G10, Usha-Lexus-303B models supp | YellowBoss | Service Products News & Updates | 0 | 03-23-2010 09:50 |
23 Mar 2010: Coral-450, HT-Mobile-G10, Usha-Lexus-303B models supported | YellowBoss | Infinity-Box | 0 | 03-23-2010 09:46 |
Hello infinity team hear is i am read usha lexus 838b 100% ok set | debmobile | Infinity-Box | 2 | 09-28-2008 08:13 |
HELLO mr JACK-CHINA CAN YOU UPLOAD THIS READED 100% OK SETFILE MODEL USHA LEXUS 838B. | debmobile | SpiderMan | 1 | 09-26-2008 16:11 |
Usha Lexus Connet Ok With Spiderman | sahil2000ind | SpiderMan | 1 | 08-09-2008 18:53 |
