12-14-2009, 18:46 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: algeria
Member: 591880 Status: Offline Thanks Meter: 561 | any one have a beckup for this phone (CECT T689 CPU2) i need beckup for this CECT T689 2sim cpu MT6226 16m i have this message when a want to format Code: Warning: probably flash chip is empty, erased, incorrectly flashed or damaged ! What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. D:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. D:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin detecting chip #01 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 01000000 searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: .old firmware type w/o rom info data .damaged firmware .damaged hardware if phone works fine just ignore this warning detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 flash: EC257E25082501:FFFFFF00000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: _ffs... file saved: D:\Program Files\InfinityBox\ChineseMiracle\_ffs_20091214-184057.B0E.bin flash: EC257E25082501:FFFFFF00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... ffs formatting... flash: EC257E25082501:FFFFFF00000000 Finalization Done Finished, time used: 293 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
did any one HAVE user manual FOR THIS BUGY BOX | sayedhas | UST Pro II | 9 | 07-10-2007 08:02 |
Any One Have The Settings For Ptt??? | Dr cellular uk | Nokia Base Band 5 ( BB-5 ) | 1 | 12-23-2006 20:32 |
ANY ONE HAVE PM file for 6230B | Peke_Alabang | UFS2 + UFS3-Tornadoflasher | 1 | 09-23-2005 20:31 |
any one have anti-thief for nokia 6600 | varun007 | Nokia Multimedia | 1 | 09-02-2005 16:46 |
any one have IDEA to unlock this BF4 came from Orange France | GSM SNIPER | BF, BG, TH, BHx Series | 29 | 07-02-2004 11:38 |
