Old 09-04-2015, 08:40   #1 (permalink)
pankajkukar2's Avatar
Member: 609329
Sonork: 100.160.2296
Thanks Meter: 143
Exclamation any solution for cobo launcher virus?
from some days a virus effect many android phones , which install a launcher name cobo launcher and start 2 service in background 1. time service 2. monkey test, solution is only flash handset till now, any solution is in cm2mtk tool for this? if yes plz tell,thx
Old 09-04-2015, 09:41   #2 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
format with cm2 or flash it no other solution for this as i face same problem and i not found any other solution
Old 09-05-2015, 08:49   #3 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
There is thousand of viruses for Android OS. Possible kill every, but need know exactly, which , what, when and how it done to make something actions against it.
So , if someone ready spend 5-10 hours to every virus to analyze it process, activity, damage, actions - then collect all this data, and send me - sure, can add.
I sure on 146% - there is will be NO ONE, who will do this.
We are make sw for repair, not antivirus, so can't spend huge of time to that thing at all.
The Following 4 Users Say Thank You to JayDi For This Useful Post:
Old 09-06-2015, 05:52   #4 (permalink)
Member: 2373427
Thanks Meter: 43
OK sir plz check OPPO r831k ;time service; error after format and flash error not gone plz check
MT6572__OPPO__R831K__R831K_11_A.14_150602__Android _4.2.2__20150602_074358 - Download - 4shared
Old 09-06-2015, 05:56   #5 (permalink)
JayDi's Avatar
Member: 462970
Read my post again - I WILL NOT check anything, because instead of waste time on that, I can make new and interest soltuions.
If Format FS NOT help - that mean SYSTEM is damaged by virus. Say thanks to "Root" solutions, which make a big hole for different worms from a phone.
The Following 3 Users Say Thank You to JayDi For This Useful Post:
Old 09-23-2015, 08:44   #6 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 4,073
Hello,
my question
will it done(monkey test etc virus) with Format (with CM2) or must have to flash it with firmware?
because its common virus in our area (some time can't arrange/download firmware)
so format is enough??
Old 09-23-2015, 08:54   #7 (permalink)
JayDi's Avatar
Member: 462970
Hello.
That is why I not want adding ROOT feature
If phone rooted - then in some cases - it can be left in system. In most cases - FORMAT FS will kill all viruses.
The Following 2 Users Say Thank You to JayDi For This Useful Post:
Old 09-23-2015, 09:06   #8 (permalink)
Member: 654997
Thanks Meter: 4,073
Hello,
And if phone is rooted or must have to flash to remove virus(monkey test- time service etc)
can i read firmware from faulty phone and write it back to same phone?
Example:-http://forum.gsmhosting.com/vbb/f296...ution-1992041/
Old 09-23-2015, 09:15   #9 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
Originally Posted by syed tuqeer View Post
Hello,
no u need read fresh set without virus infected and also need full erase set before flash
i face this problem many time and after flash problem solve
Old 09-23-2015, 09:17   #10 (permalink)
JayDi's Avatar
Member: 462970
Read FW and write it back - change nothing, if format not remove virus. You will need read from working phone.
The Following User Says Thank You to JayDi For This Useful Post:
Old 10-30-2015, 15:09   #11 (permalink)
Member: 2476003
Sonork: 100.1664157
Thanks Meter: 11
hi are there any solution about andriod monkey virus without flashing
Old 10-30-2015, 16:17   #12 (permalink)
JayDi's Avatar
Member: 462970
Since month in one button.
Page generated in 0.19615 seconds with 8 queries
