03-04-2009, 21:20 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: TUNISIA-KEBILI Age: 44
Member: 108627 Status: Offline Thanks Meter: 307 | Anycool d66+ white screen done thx infinity and the flash files used "E553_K10F8_E553_GPRS_MT6226_S01.00_0__Anycool-D66+_1x18pin_rx7_tx9_16m_En_Ru_Fr_Es_De_Id_Th_Vn_T r_Ar.B0M.bin " Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:8DF6:25C3 high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.48860083.[E553_K4SMCHARAB_E553_GPRS_MT6226_S01.01_1.BIN_A36E 3A79].rpl identification#1 detection finished device-id: 48860083 identification#1 protocol ver: 04 ver. sw 1: E553_K4SMCHARAB_E553_GPRS_MT6226_S01.01_1.BIN ver. sw 2: E553_K4SMCHARAB.01.1, 86C5915C ffs offset/size: 00800000/001FF000 detect device identification#2... detection phase #1.... detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00800000 flash: EC257E25082501:29EA0000000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 Detected eeprom/ffs address is non-standard: 00E00000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address confirmed by user: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[E553_K4SMCHARAB_E553_GPRS_MT6226_S01.01_1.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[E553_K4SMCHARAB_E553_GPRS_MT6226_S01.01_1.BIN]_20090304-184925.B0E.bin flash: EC257E25082501:29EA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... detect device identification#2... detection phase #1.... detect device identification#2 finished security area (code #1) calculation... done detecting security area (code #2)... security area (code #2) is absent file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_48860083_E553_K4SMCHARAB_E553_GPRS_MT622 6_S01.01_1.BIN_A36E3A79_20090304-184933.B0X.bin Area: Firmware flash: EC257E25082501:29EA0000000000 Write: Firmware detect device identification#2... detection phase #1.... detect device identification#2 finished Write Done Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_48860083_E553_K4SMCHARAB_E553_GPRS_MT622 6_S01.01_1.BIN_A36E3A79_20090304-185509.B0X.bin Finished, time used: 543 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to limem2003 For This Useful Post: |
Anycool with white screen | bad_signal | SpiderMan | 12 | 04-19-2010 10:30 |
k600i white screen done ufs semc tool crack.. | gravity_83 | Sony Ericsson | 1 | 03-02-2009 09:32 |
3230 white screen....done | vintel | Nokia Hardware & Hardware Repair | 6 | 01-12-2009 08:46 |
K618i WHITE SCREEN DONE BY SETOOL. | ALEXIS_089 | Sony Ericsson | 0 | 12-22-2008 18:34 |
anycool d66+ white lcd | ahwak | SpiderMan | 7 | 12-21-2008 17:22 |
