Old 02-26-2008, 10:32   #1 (permalink)
Registered User
Member: 55026
Thanks Meter: 53
Anycool F818 seccond IMEI can not be written..
I have found seccond pins for Anycool F818 but when try to change seccond IMEI with method 3 it always says tunoff phone and then turn on without removing battery. I do all as software want.. but no succues to write IMEI, always error. Please help!
regards
Originally Posted by s.Mobi
I upload edited file for you on rapidshare, you can download it from this this link:
http://rapidshare.com/files/94930127..._16_V1_0..html
if you need, change picture in firmware with Picture Editor.
My friend! how did you edited this firmware? wil it show turkish lang in the phone..? what dictionary you used.. I see translation is very bad.. customer will not accept this.. may I correct it? if I make correction will it be effected to the firmware?
regards..
You can edit this firmware as you wish. Abiut dictionary - sorry, but i don't know turkish language and use only dictionary maked by testers.
OK I will try to corect it and upload..hope iy will show..
one more:
I am trying to chanhe Seccond IMEI on anycool F818 but Always I get this error, software tell me poweroff and on, I do but then phone can not boot..
OM4 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: imei
imei write method: mode-3
new imei: 351113*********
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6223:8A04]...
CPU: MT6223
chip: 0011:6FB3:000C
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: BF7353FFFF0052:2AEA0000000000
flash: SST SST34HF3244/3284 U 4Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
detecting chip #04 in region #00...
detecting chip #05 in region #00...
detecting chip #06 in region #00...
detecting chip #07 in region #00...
number of flash chip/regions detected: 08/01
Initialize Done
Set baud...
460800
Set baud Done
Identification...
device parameters autodetection in progress..
it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 00400000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw1: E558AGENT_V60_MT6223S00.01_1_20071113.BIN
ver. sw2: E558AGENT_V60.01.1, 00000000
ffs offset/size: 00380000/00080000
detect device identification#2...
warning: optional information not found
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00380000
checking area[00000000]: 00000000-003FFFFF...
eeprom/ffs found near: 00380000
detecting eeprom/ffs size...
eeprom/ffs size: 00080000
ffs chip: 00
eeprom/ffs area: 00000000:00380000-003FFFFF
reading [eeprom[E558AGENT_V60_MT6223S00.01_1_20071113.BIN]]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\ANYCOOL\backup_ee prom[E558AGENT_V60_MT6223S00.01_1_20071113.BIN]_20080226-110945.B0E.bin
Identification Done
Manipulation...
imei is not detected !
What to do:
1. Power-On phone, Power-Off by "Power" button, don't remove battery !
2. Repeat "imei repair" procedure again
If still no luck: read flash and send to support
Manipulation Fail
Finished, time used: 323 sec
Remove/Install battery now !
Old 02-26-2008, 15:28   #2 (permalink)
Member: 148515
Thanks Meter: 14,899
hello!
what result gives IMEI writing with First and second method?
Old 02-26-2008, 16:04   #3 (permalink)
Registered User
Member: 55026
Thanks Meter: 53
first and seccond methot no connection with phone..
but when I write first time software said something like, can not write to area 0:00F........ after that always gives the error above..
Old 02-26-2008, 20:39   #4 (permalink)
Member: 148515
hello!
please give us few days to improve operation with this Flash type
Old 02-27-2008, 19:36   #5 (permalink)
Member: 148515
hello mr. KUBAT1!
we finished testing with this flash IC type.
today few hour later will be uploaded improved version with this bug corrected.
I hope you still have this phone on hands to make tests
Old 06-29-2008, 20:08   #6 (permalink)
Member: 542291
hello.
i have this problem too.
pls help me infinityhelp.
i cant change 2 imei for anycool and n72 and .... in 3model.
i bay mctool box for that problem.but i cant do that.
pls help me.
my mail is [email protected]
tnx
Do not use R1N035 FW for K750i/W800! Harms GDFS area and it can not be reversed! MG77 Cruiser Suite 9 12-06-2005 14:28
3200 can not be unlocked!!!Guys this is not cable silvester Griffin 11 12-15-2003 22:25
3310 can not be flashed AssenBG Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 10-09-2001 15:02
8210 v 5.26 than can not be readed with any soft Kilowat Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 08-11-2001 18:49
Page generated in 0.31532 seconds with 8 queries
