11-17-2008, 15:23 | #1 (permalink) |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | AnyCool T818 Second IMEI is Changing Automaticly.. when i changed the first imei, second imei changing too.. detailed information... Code: COM136 [VCP0] selected module v2.65 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read/check detailed information Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:EE03:0009 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: LC6225_GEMINI_PCB01_GPRS_MT6225_S00.LBN8416_8_12_1_0T01M0910_M401A.BIN ver. sw2: LBN8416.8.12.1.0T01M0910_M401A, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 98004900000002:18E59F00000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF detecting ffs structure pass 1... ....................... detect standard fat location pass #1... ..................................................... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #1 detected ok detecting ffs structure pass 2... ....................... detect standard fat location pass #1... ..................................................... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #2 detected ok Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... Finished, time used: 57 sec Remove/Install battery now ! |
11-17-2008, 16:34 | #2 (permalink) | |
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
supporters r u there..? | |
The Following User Says Thank You to LoveLess For This Useful Post: |
11-17-2008, 23:21 | #6 (permalink) |
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | hi sir.. actually i dont dissamble the phone soo i dont know that phone has single or not.. but i think it has one cpu..and second imei is changing this type.. f.e. i m changing first imei to ; IMEI M: 35XXXXXXXXXX25 IMEI S: 35XXXXXXXXXX52 |
12-02-2008, 10:44 | #11 (permalink) |
No Life Poster Join Date: Sep 2000 Location: Turkey Age: 43
Member: 2088 Status: Offline Sonork: 100.1630154 Thanks Meter: 57 | i changed the imei on mode-2 result is imei2 changing automaticly.. but sim2 is always unregistered.. with correctly new imei. i do it complate format and then write imei again but not solved is sim2 unregistering. anyone have any idea ???? |
anycool t818 cpu2 pinout help | cenk kamil | Infinity-Box | 4 | 07-17-2009 09:19 |
Verry main problem second imei not changed | ayaz ali | Infinity-Box | 2 | 05-06-2009 20:14 |
5310 after unlock imei is changed | tareen | Universalbox | 4 | 04-02-2009 09:55 |
anycool t818 pinout? | Sheriff | Chinese Models & Cloned Phones | 0 | 05-20-2008 18:14 |
CESIM V30 second imei not change with infinity pls help | mertsaid | Infinity-Box | 4 | 02-03-2008 10:42 |
