08-05-2015, 15:22 | #2 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | I can't connect to this: Code: Card found: S/N 0714:0xx8 Chinese Miracle II [MTK module] v 1.25 Operation : Check / Read Info [ v1.25 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6795 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] Helio[X10]|MT6795 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending Error : DA init Failed! Error code : 0x2 Boot Error! Operation Failed Elapsed: 00:00:18 Reconnect Power/Cable! |
08-05-2015, 17:37 | #3 (permalink) |
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | P.S. Phone is alive and working with WWW-Asia base, just want to backup it if it's possible, due to see that original 0PJXIMG_A55ML_DTUL_L50_SENSE70_HTC_Europe_1.30.401 .6_Radio_1.1506V24P21.2003.0505_AD5[W.T]_release_434827_signed zip files are encrypted and inside is just userdata and cache images accessible. |
08-05-2015, 17:52 | #4 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
And yes - it uses secure loader, and any moves with it can kill it completely. With 6795 all is pretty bad about damaged samples repair. I hope E9+ will be available soon and it has more real price. | |
08-05-2015, 18:04 | #5 (permalink) |
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | It's E9+ unit in hands and i can open a teamviewer connection to play with it - i was make now TWRP backup, just in case of faults. And my unit is x.xx.709.x based - that is Asia_TW, not Asia_WWE - my mistake |
08-05-2015, 18:12 | #6 (permalink) | |
It not a way for PC, where is working other boxes and e.t.c. Also, if will be made some mistake - it is not 100$ phone , so, better will find sample on hands. Will be no problem spend on it hour-day-week and not disturb anyone and scare about killing that phone. I already try play with M9+ remotely - no a big success for 4 hours, so, better will be find sample and play by myself. Also - NOT recommend flash it, until you not sure about correct SPFT version exactly for this type. It can be booted, flashed, and bricked as result. Completely. | |
