10-08-2017, 07:22 | #1 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Anyone with SPD SC6531E on hands? CM2SPD should not boot them at all. |
10-08-2017, 09:03 | #2 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | Hi, My friend having this phone model Intex Eco Selfie box pack if you want for RND I can gift you but you will need to send someone to collect Thanks Good Luck |
The Following User Says Thank You to gracy_elec For This Useful Post: |
10-08-2017, 09:06 | #3 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | Description Chipset SC6531E Dimensions ( L x W x D) 115 x 48 x 15.3 mm Weight (Gms) 86.5gram(with battery) Display Colors 262K Display Resolution 128*160 Form Factor Bar Feature Display Size 4.5 cm (1.8) Screen Type TFT Battery 1800mAh Talk Time 16 Hrs* Standby Time 550 Hrs* Battery Type Li-ion Charging time 3 - 4 Hrs USB-PC Connectivity (Mass Storage) Yes Network GSM + GSM GPRS / WAP YES Wi-Fi/ BT Bluetooth V2.1 with A2DP Internal Phone Book Memory 1500 only Internal SMS Memory 100 Expandable Memory 32 GB Internal Phone Memory 34.5KB Mobile Tracker Yes Auto Call Record Yes Language Support English/Hindi Pre-Loaded Games Tweety Bird Slim iV2 & Brick N Ball iV2 Torch Light Yes(Flash work as a Torch) Black List (Block calls from unwanted numbers)/White List (Receive calls from desired numbers) Yes/Yes Multi-language Support 22 Language Fun Club Yes File Manager Yes Image Viewer Yes Video Player Yes Video Recorder Yes FM Recording Yes Sound Recorder Yes Audio Player Yes Contact to Display Yes Handset Lock ( Numerical ) Yes Music Timer Yes Songs (Next & Previous) Yes Screen Shot Yes Smart Divert Yes Restore All Yes Long Press 8 Key for Call Mute Yes SOS Key on 5 Yes List of applications Calendar, Calculator, Alarm, World Clock, Stopwatch, Torch, BT, Screenshot, Auto call record, STK Fun Store Preloaded Browser Yes Internal Flash Memory 32 MB + 32MB Earphone jack type 3.5 mm Charging Jack type/additional nokia pin? 5 Pin Micro USB List of Accessories Battery, Charger, User Manual, Language manual, Earphone Any other good Feature/thing in the product Wireless FM with Schedule recorder, Handset Lock, Phone Book 1500 (Phone-1000, T Card-500), SMS 100, GPRS/WAP, Camera with Flash, Smart Divert, Screenshot. Video Supported Format 3GP,MP4 Audio Formats Supported AAC / MP3 / WAV / AMR FM Radio Wireless FM with recording Camera Rear & Selfie Camera with Flash Earphone (Jack Type/ Single Or Double Bud /Mic/length) 3.5 mm/YES |
10-08-2017, 09:24 | #4 (permalink) |
Freak Poster Join Date: Apr 2016 Location: BEHIND OF YOUR GIRL FRIEND...
Member: 2559619 Status: Offline Sonork: 100.1672420 Thanks Meter: 205 | Ntex eco 210+ not boot with cm2 HELLO SIR INTEX ECO 210+ ALSO SPD 6531A INSIDE. NOT BOOT WITH CM2... Intex_ECO 210+_V07_AIRL_India_SER.pac PLZ ADD NO IT HAND..WILL CONTECT U LATER SIR WHEN ITS IN MY HAND.... |
The Following User Says Thank You to RIZU007 For This Useful Post: |
10-08-2017, 19:09 | #5 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Hello. If you get device on hands - let me know. And also log of identify required. | |
10-09-2017, 04:12 | #7 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | Quote:
Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 8 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot didn't start! Check model selection! Boot Error! Break Reconnect Power/Cable! | |
10-11-2017, 06:17 | #12 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Quote:
Code: Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 14 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : SEND_ERROR_RSP(0x97) func:_FDL_HWInit, line:458 3è~~ Boot Ok READ INFO PHONE MODEL | |
10-11-2017, 06:51 | #13 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Dera Ismail Khan (KPK) Pak
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Phone found! [ 24 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot didn't start! Check model selection! Boot Error! Break TWO PIC IN MY HEAND |
