Old 12-25-2008, 23:48   #1 (permalink)
Member: 203445
Thanks Meter: 48
Anything for this please ?
COM5 [VCP0] selected
module v2.69
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: read eeprom
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot enabled
chip: 0001:3903:0004
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 2088C4FFFFFFFF:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud ...
230400
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw 1: S9.XYDL.T1.F0.U1.L8.V3.01.BIN
ver. sw 2: S9.XYDL.T1.F0.U1.L8.V3.01, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00440000
Detected eeprom/ffs address is non-standard: 00440000
Posible reasons:
1. eeprom is Ok but address is non-standard
2. eeprom damaged and can't be detected
3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make flash backup for emergency case
3. repeat required operation
Are you sure that detected eeprom address is correct ?
Do you want to use standard eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
terminated by user
error: critical error#1 during ffs size detection
error: can't detect eeprom/ffs address/size
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Finished, time used: 81 sec
Remove/Install battery now !
e-gsmshop
Old 12-26-2008, 00:01   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
upload this firmware to www.rapidshare.com and post link here.
i will check it
Old 12-26-2008, 10:16   #3 (permalink)
Member: 203445
Thanks Meter: 48
hello!
i will check it
Flash files : http://rapidshare.com/files/17687111...4.B0M.bin.html
Eeprom files : http://rapidshare.com/files/17687289...5.B0E.bin.html
Thanks for your helps
e-gsmshop
Old 12-26-2008, 12:33   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
@e-gsmshop
btw, what is the problem with phone ?
I can not understand the problem.
You have posted only log but no any problem description. Why ?
Anything for this Please ? e-gsmshop Universalbox 2 11-16-2008 10:54
Anything for This ? gsavv723 MT-BOX 1 10-29-2006 23:39
Anything for This ? gsavv723 Cruiser Suite 4 05-11-2006 01:34
Dear Andro Anything for this ? gsavv723 MT-BOX 1 04-30-2006 10:32
Need Key, Patch, Crack or anything for this software imran_qasim Bluetooth-Software 2 09-17-2005 07:02
Page generated in 0.19054 seconds with 9 queries
