06-28-2006, 14:57 | #1 (permalink) |
No Life Poster Join Date: Aug 2004 Age: 47
Member: 76522 Status: Offline Thanks Meter: 30 | ap75 problem COM2 selected Device: BenQ M315, Siemens AP75 Checking data, wait... Action: Flash write Write: Firmware Skip: Flex Write: Language Pack Skip: Eeprom Smart Write active Boot... Phone should be Switched OFF ! Connect test-point to Ground ! Press Power button now ! Connecting... Disconnect test-point ! Boot Done Check Connection... Check Connection Done Set Baud... 812500 Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:885500010001 Check Space Done Check Data... Check Data Done Erasing... erase operation canceled due to not required Erasing Done Writing... Write: Firmware Flash: 0089:885500010001 Write: Language Pack Writing Done Finished Remove/Install battery now ! Time used: 285 sec |
06-29-2006, 08:55 | #3 (permalink) |
Member: 76522 Status: Offline Thanks Meter: 30 | yes thx 4 great and fast help. in my case main 133 + lp140 goes error ppt repair eeprom wont help. main 133 + 129 error ppt. main 129 + lp140 work ok. may be other combinations work too but i dont try. |
08-03-2006, 11:11 | #4 (permalink) |
Junior Member Join Date: Aug 2001 Location: sidi slinane Age: 50
Member: 5935 Status: Offline Thanks Meter: 2 | please help my phone is dead now after traying chang lang COM1 selected Device: BenQ M315, Siemens AP75 Checking data, wait... Action: Flash write Write: Firmware Skip: Flex Write: Language Pack Skip: Eeprom Smart Write active Boot... Phone should be Switched OFF ! Connect test-point to Ground ! Press Power button now ! Connecting... Disconnect test-point ! Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:885500010001 Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0089:885500010001 Err: error flash command try to recover erase error#43 |
08-03-2006, 11:14 | #5 (permalink) |
Member: 5935 Status: Offline Thanks Meter: 2 | AP75 Dead after flashing please help my phone is dead now after traying chang lang COM1 selected Device: BenQ M315, Siemens AP75 Checking data, wait... Action: Flash write Write: Firmware Skip: Flex Write: Language Pack Skip: Eeprom Smart Write active Boot... Phone should be Switched OFF ! Connect test-point to Ground ! Press Power button now ! Connecting... Disconnect test-point ! Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:885500010001 Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0089:885500010001 Err: error flash command try to recover erase error#43 |
acount id problem.help uregent plz [SOLVED] | dani2080 | PolarBox 3 | 2 | 03-29-2010 12:46 |
unlock benq ap75 problem ::: SOLVED ::: | psilva | PolarBox 3 | 27 | 02-19-2009 00:11 |
AP75 problem after unlock | bogdancirlogea | Infinity-Box | 6 | 12-23-2006 12:06 |
Seimens Ap75 problem | almoudamer | FuriousGold | 3 | 08-18-2006 15:23 |
AP75 problem | Bigbrothers2000 | Infinity-Box | 3 | 05-15-2006 10:54 |
