06-15-2017, 23:29 | #1 (permalink) |
No Life Poster Join Date: Apr 2011 Location: algerie Age: 54
Member: 1562854 Status: Offline Sonork: 1245 Thanks Meter: 259 | Archos 45 Helium 4G flash problem Card found : 7DBA7787 , v0136 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.13 Loading firmware ... userdata : C:\Documents and Settings\Administrateur\Bureau\Archos 45 Helium 4G\MSM8226__archos__archos__ANDR_v4.3__Archos_45_H elium_4G__a45he__qca45he\userdata.img Firmware load error! Firmware incomplete! Some files are missing! Loading firmware ... Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : archos Device Manufact.: archos Device Model : a45he Device CPU : MSM8226 Device IntName : qca45he Device Version : 4.3 CU_SWVer : archos Device Compile : 21/08/2014 09:35:43 Device ExtInfo : Archos 45 Helium 4G Load Ok! Operation : Flash [ v1.13 ] ForceFlashing : Enabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 400 [MSM8x26/28] ID_BLOCK_S : 00E5343F ID_BLOCK_I : 008050E1 ID_BLOCK_L : 44BCD6208F1B0003FC51A3AC6B36BE8E ID_BLOCK_L : BCD779D0C54CFE778A652EE7ED001E3D Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8x26 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000/00000000 Boot Ok! Flash Chain : 28 Flashing now Flashing : gpt_main0.bin Flashing : NON-HLOS.bin Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : deploy.mbn Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : boot.img Flashing : tz.mbn Flashing : tz.mbn Flashing : system.img Flashing : persist.img ProgStart : start 2276418, num 16 ProgFinish : Read back verify failed at sector -1792406620,num sectors 2276418 Flash Error , No ACK message! Check Battery charge , Cable Error : Flashing failed! Check previous message for more info! Reconnect Power/Cable! |
