02-21-2017, 19:37 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: Bacau
Member: 148032 Status: Offline Thanks Meter: 415 | Archos 50c platinum FRP ??? I had tryed with QLM Module but I can't connect it anyone knows how to conect this phone for reset? Archos 50 Platinum - Full phone specifications |
02-23-2017, 00:15 | #4 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,827 | Dear Friend, Something Wrong, Archos 50 Platinum Has Qualcomm MSM8225Q Android 4.1.2 That Mean FRP Not Possible. Archos 50c Platinum Has SC7731 That Mean You Can Remove It By Using CM2SPD. Last edited by MyGSM World; 02-23-2017 at 00:21. |
The Following User Says Thank You to MyGSM World For This Useful Post: |
02-24-2017, 21:49 | #5 (permalink) | |
Member: 148032 Status: Offline Thanks Meter: 415 | Quote: | |
The Following User Says Thank You to dragosgsm For This Useful Post: |
02-27-2017, 13:48 | #6 (permalink) |
Member: 148032 Status: Offline Thanks Meter: 415 | Managed to connect it but sill asking for google account: Operation : Format File System / Reset Settings [ v1.22 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 394 ] Port Opened Sync... InitSvc Done Wait for phone... Sync... Init Ok , reset settings ... Format Ok! Done Elapsed: 00:00:26 Reconnect Power/Cable! |
03-15-2017, 17:44 | #8 (permalink) |
Member: 148032 Status: Offline Thanks Meter: 415 | Phone still asks for google account even oparion is succesfull: Operation : Format File System / Reset Settings [ v1.24 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 394 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000032C7F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
03-26-2017, 09:24 | #11 (permalink) |
No Life Poster Join Date: Jun 2005
Member: 154448 Status: Offline Sonork: not yet Thanks Meter: 51 | hello friend i need help in archos 50c frp Card found: S/N : *******F , v0135 Chinese Miracle II [SPD module] v 1.24 Operation : Check/Read Info [ v1.24 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 79 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : SCAC50DNE Model Brand : archos Model Device: ac50dne AndrVersion : 5.1 BaseBand CPU: SP7731GEA_HD CompileDate : 21/03/2016 20:23:56 Project Ver : Archos_50D_Neon_Android_5.1_V07_2016....202356.Fatsia Model Ext : Archos 50d Neon ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:31 Reconnect Power/Cable! |
