02-20-2016, 11:28
#1 (permalink)
Member: 2501288
Thanks Meter: 328 | ARCHOS 55 Platinum SC7731g remove FRP problem hi
ARCHOS 55 Platinum SC7731g remove FRP problem Quote:
Start at : [19/02/16 / 19:37:00]
Operation : Format File System / Reset Settings [ v1.15 ]
Settings : SmartFormat is On
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
==== Wait for phone...
Phone found! [ 29 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
Boot failed!
Loader start failed! Wrong Model selection!
Boot failed!
Reconnect Power/Cable!
Finish at : [19/02/16 / 19:37:17]
SLDR Load Ok
BB CPU : SC7731
SC773x eMMc Loader v2.0
For disable SLDR - select PAC or other SLDR or re-select CPU in settings tab!
Start at : [19/02/16 / 19:38:00]
3. Insert cable
Phone found! [ 29 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC773x eMMC v2.0 Loader Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Unknown structure detected! Something went wrong
If phone work normally - check correct selection (Model,FlashType)!
Elapsed: 00:00:08
Finish at : [19/02/16 / 19:38:09]
Start at : [19/02/16 / 20:09:07]
3. Insert cable
Phone found! [ 29 ]
Port Opened
Sync...
Initial Boot Failed!
Finish at : [19/02/16 / 20:09:20]
SLDR Load Ok
BB CPU : SC7731
HTC 326G UMS SEC
Start at : [19/02/16 / 20:23:09]
3. Insert cable
Phone found! [ 29 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : Spreadtrum Boot Block version 1.1
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Elapsed: 00:00:12
Finish at : [19/02/16 / 20:23:22]
SLDR Load Ok
BB CPU : SC7731
Huawei Y336-U02 (Y3C)
Start at : [19/02/16 / 20:23:42]
Operation : Check/Read Info [ v1.15 ]
3. Insert cable
Phone found! [ 29 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [19/02/16 / 20:23:58]
SLDR Load Ok
BB CPU : SC7731
Huawei Y541-U02 (Y5C)
Start at : [19/02/16 / 20:26:50]
3. Insert cable
Phone found! [ 29 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Unknown structure detected! Check correct model selection!
Elapsed: 00:00:14
Finish at : [19/02/16 / 20:27:05]
SLDR Load Ok
BB CPU : SC7731
Huawei Y560-U02 (Y5C)
Start at : [19/02/16 / 20:27:26]
3. Insert cable
Phone found! [ 29 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Elapsed: 00:00:12
Finish at : [19/02/16 / 20:27:39]
SLDR Load Ok
BB CPU : SC7731
SLDR Load Ok
BB CPU : SC7731
SC7731 Alcatel
Start at : [19/02/16 / 20:28:11]
3. Insert cable
Phone found! [ 29 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [19/02/16 / 20:28:26]
SLDR Load Ok
BB CPU : SC7715
SC7715 eMMC UMS 4G512M v1
SLDR Load Ok
BB CPU : SC7731
SC7731 eMMC UMS 4G512M v2
Start at : [19/02/16 / 20:28:54]
3. Insert cable
Phone found! [ 29 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [19/02/16 / 20:29:13]
SLDR Load Ok
BB CPU : SC7731
SC7731 eMMC 4G512M v1
Start at : [19/02/16 / 20:42:07]
3. Insert cable
Phone found! [ 29 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [19/02/16 / 20:42:29]
========================= Start =========================
20/02/16 / 10:26:16
Card found: S/N : xxxxxxxxx
Chinese Miracle II [SPD module] v 1.15
