Old 11-19-2007, 01:40   #1 (permalink)
Member: 196459
Thanks Meter: 8
Ask File Can't Be Created
these days when ever i try to flash any chinese phone the software says ASK file cannot be created and the set is dead. i have about 3 N95 phones with this problem. at first i was not having such problems. i even tried to flash a phone that was flashed by me before and ask file was created for RPL calculation. after flashing this set agan software told me ASK file cant be created and set is dead, believe me this set was flashed by me before and i succeeded with ask/rpl calculation but after trying again its dead. WHATS THE PROBLEM? customer is about to toast me
kwamena
Old 11-19-2007, 02:35   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
the best way to get answer in your situation:
1. post log here so I can check what is the problem
2. write here what flash files you have used
Old 11-22-2007, 17:16   #3 (permalink)
Member: 196459
Thanks Meter: 8
please check log and help
infinity team here is the log after trying repair security area
ffs offset/size: 00E00000/00200000
warning: invalid security area, re-calculation reqired
warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.CB031E45._T622 6_05C_PCB01_GPRS_MT6226_S01.B22_SX2731FLASH_LCD_JY .BIN_CA8BA4E9_.rpl
warning: unknown identification structure: T6226_05C_PCB01_GPRS_MT6226_S01.B22_SX2731FLASH_LC D_JY.BIN_CA8BA4E9
error: Unknown firmware, user action required:
1. download latest software from support area and try again !
2. if no still luck follow the next procedure:
- find good working phone with the same firmware:
- make "Read detailed information" operation
- send "backup_system_log_..." file to support
- make "Read full flash" operation
- send flash backup file(s) to support
- include in your e-mail full text from phone back label (phone name etc.)
- be little bit patient and wait update
Finished, time used: 96 sec
Remove/Install battery now !
Old 11-22-2007, 18:02   #4 (permalink)
Member: 130995
Please, read text in yellow color
Old 11-22-2007, 18:27   #5 (permalink)
Member: 196459
Thanks Meter: 8
yes thats what i'm talking about, i have been able to flash this phone before and also succeeded with ask/rpl calculation with the same firmware so i dont know why this time around its giving me this problem.
Old 11-22-2007, 20:29   #6 (permalink)
Member: 196459
Thanks Meter: 8
infinity team any idea? has anybody faced such a problem before? please suggest somehing? customer is on my neck
Old 11-23-2007, 01:35   #7 (permalink)
Member: 130995
How about to follow at least first step from instruction ?
Did you tried to read instruction given by software ?
also, I am sure that if software say you this info now it was not posible to flash this phone before. Probably it was other firmware version.
Old 11-23-2007, 11:02   #8 (permalink)
Member: 196459
Thanks Meter: 8
i'm using the latest chinese miracle 2.02
Old 11-23-2007, 11:24   #9 (permalink)
.::BHATTI::.'s Avatar
Member: 203158
Sonork: 100.1592032
Thanks Meter: 358
did u try repairing security area.......
Old 11-23-2007, 15:49   #10 (permalink)
Member: 130995
According to text from your log I think that you have used more old version. Please, double check what software you have used.
Old 11-24-2007, 11:19   #11 (permalink)
Member: 196459
Thanks Meter: 8
i have updated to 2.02 still same problem
Old 11-24-2007, 11:29   #12 (permalink)
Member: 203158
Sonork: 100.1592032
Thanks Meter: 358
Use the Good Firmware anf try to repir security area
ur problnme will be solved 100%
Old 11-24-2007, 17:21   #13 (permalink)
Member: 130995
Hello,
Please, read instruction in yellow text: http:///vbb/showpo...24&postcount=4
nfp file can't be opened specta Nokia CDMA 2 02-14-2010 10:34
this file can't be load,no enough access rights siang8788 Infinity-Box 2 03-11-2008 15:52
Need create a ask file but give error ct3im Federal One 2 12-14-2007 04:25
USB: Creating ASK file...RapID invalid! telemedia2006 Federal One 4 07-17-2007 19:57
Which ask File have i to create ??? Hossi Griffin 0 09-25-2004 12:42
Page generated in 0.24642 seconds with 9 queries
