Old 03-13-2011, 15:13   #1 (permalink)
Member: 1189070
Thanks Meter: 167
Q-Mobile Q55 Successfuly Killed By Infinity Box
Dead Q55 By Formatting via Infinity But I Flash With Old Firmware And New Too but no success Need Help
COM137 [VCP2] selected
module v3.26
Device: Autodetect 6228-6253 NAND
Checking data, wait...
Action: write flash NAND
write: Firmware
TINNO35_09A_PCB01_GPRS_MT6235B_S01.E580-2_MP_F1_PK_01_05__firmware_20110313-162710.B4M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
nfi area detection...
bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E580-2_MP_F1_PK_01_05.bin
nfi area detection (3 cores) finished: Ok
"format ffs" active
interface: BROM_DLL_v3.1016.00
Connect...
Connecting...
Booting...
Release Power button now !
bootcode current/expected: 3.2/3.2
CPU: 6235:8A04:8A01
status: FF
bbchip bl ver: FE
NOR flash chip: not installed
NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M
chip size: 64Mb
page/spare size: 0200/0010
pages per block: 0020
bits i/o: 08
address cycles: 04
internal RAM size: 00010000
external RAM: S_DA_RAM_ERROR
done
Set baudrate (921600)...
done
ram test...
testing...
ram test passed
===> detect existing firmware structure...
detect ffs...
ffs offset/size: 02000000/02000000
firmware size: 32Mb
ffs size: 32Mb
detect sec ro...
detect custom parameters...
detect project-id...
project-id: E580-2.MP.F1.PK.01.05
detect NAND info...
number of areas/bytes to read: 1:00034000
reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)...
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
number of areas/bytes to read: 1:00004000
error: unexpected answer:
startup code area #1 is invalid
startup code area #1 detection done
rom info ver: 07
sw version: TINNO35_09A_PCB01_GPRS_MT6235B_S01.E580-2_MP_F1_PK_01_05.BIN
project-id: E580-2.MP.F1.PK.01.05, 7E88D710
code offset: 00000000
ffs offset/size [01]: 02000000/02000000
rom info structure: [protected] type (07), 1 record(s)
TCL-ID is absent
===> done
startup code area #1 check...
rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.00006235.[TINNO35_09A_PCB01_GPRS_MT6235B_S01.E580-2_MP_F1_PK_01_05.BIN_10D7887E].rpl
rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.00006235._TINN O35_09A_PCB01_GPRS_MT6235B_S01.E580-2_MP_F1_PK_01_05.BIN_10D7887E_.rpl
rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.00006235.[TINNO35_09A_PCB01_GPRS_MT6235B_S01.E580-2_MP_F1_PK_01_05.BIN_10D7887E].rpl
rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.00006235._TINNO35_09A_PCB01_GPRS_MT6235B_S01.E58 0-2_MP_F1_PK_01_05.BIN_10D7887E_.rpl
warning: unknown firmware: TINNO35_09A_PCB01_GPRS_MT6235B_S01.E580-2_MP_F1_PK_01_05.BIN_10D7887E
Unknown firmware found (v.3.26, database date: 13.01.2011), user action required:
1. download latest software from support area and try again
2. if no still luck follow the next procedure:
- find good working phone with the same firmware:
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
- be little bit patient and wait update
error: startup code area #1 can't be fixed
You can flash phone now but can not finalize it,
in most cases phone CAN NOT power-on.
Do you want to continue anyway ?
number of cores: 3
loading files...
number of areas: 3
done
write...
write bootloader...
write core...
warning: can not format: HW_STORAGE_NOR is not present
Format...
Disconnect...
done
Finished, time used: 8 min 19 sec
Remove/Install battery now !
Full Flash File Readed By Infinity
http://rapidshare.com/files/45234640...160153.B4M.rar
Old 03-13-2011, 16:28   #2 (permalink)
Member: 1189070
Thanks Meter: 167
Still Waiting Plz Do Something ...
Old 03-13-2011, 16:40   #3 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello!
What was the problem with the phone when you received it?
Post formatting log after which it become dead.
What was the original version in the phone?
You can you try to flash with latest MModule3.79 and check result.
Wr.
Old 03-13-2011, 16:52   #4 (permalink)
Member: 1189070
Thanks Meter: 167
yes i try with all firmware which posted on support area .. And I Read Full Flash File From Working Phone And Flash but still same condition Phone Dead No Powered
Old 03-14-2011, 00:03   #5 (permalink)
Member: 130995
Thanks Meter: 35,227
@Imeicodes
Software can not kill phones, only people can kill phones.
Did you tried to make a backup before operation ?
Old 03-14-2011, 08:51   #6 (permalink)
Member: 1189070
Thanks Meter: 167
Originally Posted by InfinitySupport View Post
@Imeicodes
Yes and i read full flash file from working phone but not done
here he Working Flash File can u plz check
Hotfile.com: One click file hosting: TINNO35_09A_PCB01_GPRS_MT6235B_S01.E580-2_MP_F1_PK_01_05__firmware_20110313-162710.B4M.bin
Old 03-14-2011, 09:15   #7 (permalink)
Member: 1324650
Sonork: 1600804
Thanks Meter: 11
i have also phone in same condition i have tried many times to flash in different firmwares but no success also waiting for tested solution
Old 03-14-2011, 11:19   #8 (permalink)
Member: 1189070
Thanks Meter: 167
Plz Help Me Infinity Team ...........
Old 03-14-2011, 14:49   #9 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
What was the problem in phone before flashing or formating?
B,r
Old 03-14-2011, 17:05   #10 (permalink)
Member: 1189070
Thanks Meter: 167
I Solve My Problem With GPGDragon By Flashing Thanks For Reply
Software for Nokia Mobiles Genata Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 09-20-1999 07:17
PERMANENT MOBILE PHONE SUPPLIER NEEDED MILLENNIUM-INTERNATIONAL Wanted Products 0 08-28-1999 21:23
Page generated in 0.18746 seconds with 9 queries
