Old 11-19-2016, 17:04   #1 (permalink)
trt
Member: 197566
Thanks Meter: 89
Assistant 4411 Not read pattern lock
Cant read pattern lock
Card found : S/N : 0C59D8E5 , v0134
Operation : Read Pattern/DP Lock [ v1.58 ]
Wait for phone...
Phone found! [ 48 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 8801034E436172642034E104D3224373
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x88 , OEM : 0103
[eMMC] : FLASH_INF : [FORESEE] , draC
[eMMC] : FLASH_CID : 8801034E436172642034E104D3224373
[eMMC] : FLASH_LEN : 0x00000001CE100000
[eMMC] : FLASH_UCP : 7393 MiB [eMMC 8 GiB]
DEV RID : 0x740FECF7F02B7B020B102551627257DC
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Reading data ...
[Info] : PatternLock Not Set!
[Info] : DP Lock not set!
Done!
Elapsed: 00:00:31
Reconnect Power/Cable!
Old 11-19-2016, 20:30   #2 (permalink)
princesaddam's Avatar
Member: 1010626
Sonork: using fb
Thanks Meter: 735
Hello,
Ru sure it is not any third party pattern maybe it is 6xx android version,,, use reset locks ur data will be safe
Sent from my S_plus using Tapatalk
The Following User Says Thank You to princesaddam For This Useful Post:
Page generated in 0.10609 seconds with 8 queries
