08-18-2017, 18:03 | #1 (permalink) |
No Life Poster Join Date: Jan 2006
Member: 218901 Status: Offline Thanks Meter: 64 | Asus qlm 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 625 [MSM8953] ID_BLOCK_S : C6746A4A ID_BLOCK_I : 000460E1 ID_BLOCK_E : 00290021 ID_BLOCK_L : 5FA9C33B9A000D38E75CB499663DB595 ID_BLOCK_L : 2F26E84334DF0F8439F4D9161C938DCE Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! android 7 FRP need it |
09-04-2017, 21:22 | #3 (permalink) |
Member: 218901 Status: Offline Thanks Meter: 64 | Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.15 Operation : Reset Settings [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 430 [MSM8937] ID_BLOCK_S : 8CE0E16F ID_BLOCK_I : 0004F0E1 ID_BLOCK_E : 143A8937 ID_BLOCK_L : A0BDBB0F7E1AF51D082E5C6FEFB695C1 ID_BLOCK_L : 17909ED79789914315362DD52D76532B Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! Operation : Reset Settings [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 430 [MSM8937] ID_BLOCK_S : 8CE0E16F ID_BLOCK_I : 0004F0E1 ID_BLOCK_E : 143A8937 ID_BLOCK_L : A0BDBB0F7E1AF51D082E5C6FEFB695C1 ID_BLOCK_L : 17909ED79789914315362DD52D76532B Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
